@ssax
Sent notifications are up-to-date.
I'm not seeing any errors related to the Database in usr/local/nagiosxi/var/eventman.log and /usr/local/nagios/var/event_handler.log doesn't exist.
If the 2017 date on those files is no longer a concern of yours, we'll proceed with modifying the check as suggested. Thank you.
POSTGRES_RELATION_SIZE WARNING: DB "nagiosxi"
Re: POSTGRES_RELATION_SIZE WARNING: DB "nagiosxi"
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Those 2017 date are old files and can be ignored, the main files show Jul 21 from the output. Sounds good. If the check was checking individual table sizes it would be different, this is checking the entire DB which can be a few gigs with the audit logging.
