Check for updates using the NCPA agent
Re: Check for updates using the NCPA agent
I am sending the result of the commands here. Is that enough for you?
And here I send the files you wanted.
Hello @jakai
Thanks for following up, and sending over the info. We see that we are able to get a 'check_ncpa' --list from the specified host. This means that the check is able to resolve, establish a connection with the specified host, and list out the results.
We see that the command was run using jakai user account as sudo (super user). Let's verify that the command will run when logged with the 'nagios' user account.
Then run the following:
If we see a --list resulting from the 'check_ncpa.py' command while logged in with the 'nagios' user account then we are ready to test the original command provided.
From your previously posted screenshot, you are using the plugin check_rpm.
Verify that the 'check_rpm' check script is located in the 'ncpa' plugins directory (typically located: /usr/local/ncpa/plugins/) on the '192.168.203.34'.
Let's run the following to verify:
When we get functioning results we can then enter the check into the web console in the Core Configuration Manager.
Perry
su -l nagiosCode: Select all
/usr/local/nagios/libexec/check_ncpa.py -H 192.168.203.34 -t b08TjIck2Rd2 --listFrom your previously posted screenshot, you are using the plugin check_rpm.
/usr/local/nagios/libexec/check_ncpa.py -H 192.168.203.34 -t b08TjIck2Rd2 -M plugins/check_rpm <yourargshere>Thanks,
Perry
Good day,
the last command does not work on either the nagios server or 192.168.203.34. I'm sending screens.
In the first screen you can see that the file is in its place at 192.168.203.36. The other two that the last command does not work.
Hello @jakai
Thanks for following up, and providing the screenshots.
Want to adjust the file ownership on the device that is executing the 'check_rpm' from the plugin directory.
Verify the plugin directly via shell on device:
Then verify via 'check_ncpa' directly from the Nagios XI server by:
Perry
chown nagios:nagios /usr/local/ncpa/plugins/check_rpmCode: Select all
su -l nagios
/usr/local/nagios/libexec/check_ncpa.py -H <hostaddresshere> -t <yourtokenhere> -M plugins/check_rpm
Perry
I have error. Don't you know what it can be?
Hello @jakai
Thanks for following up with the screenshot; as we know the 500 error is pretty generic. "Means that the server encountered an unexpected condition that prevented it from fulfilling the request."
Noticed that there was a 'super-user' (sudo) prepended to the command command that we provided and want to find out the results on the command with out "sudo" /usr/local/nagios/libexec/check_ncpa.py -H <hostaddresshere> -t <yourtokenhere> -M plugins/check_rpm
If the issue persists we would want you to verify that security applications, firewalls, proxy, routing, and other issues are not getting in the way. The option to look at the traffic while running the 'ncpa' service check:
Perry
tcpdump -s 0 -i any port 5693 -w output.pcapPerry
Again the same result. And the command you entered was not recognized.
Hello @jakai
Thanks for following up with the screenshot details, we see the same results, and looks like you will require to install the 'tcpdump' package from your distro's repository. Most likely one of these:
or
Once installed you can continue and run the 'tcpdump' commands.
Perry
yum install tcpdumpCode: Select all
apt install tcpdumpThanks,
Perry
Good day,
Thank you, I am sending a screen screen with the result of the command.
