As root on the Nagios XI server please run:
script /tmp/terminal.log
curl -v -k https://192.168.23.82/nagiosxi/terminal/?
exitThanks
exitCode: Select all
dnf remove shellinabox
dnf install shellinabox
systemctl start shellinaboxd
systemctl enable shellinaboxdCode: Select all
rm -f /tmp/terminal.log
ssl_error_log-20220508:[Mon May 02 19:36:40.078587 2022] [proxy:error] [pid 1283248:tid 139735634237184] (111)Connection refused: AH00957: HTTPS: attempt to connect to 127.0.0.1:7878 (localhost) failed
ssl_error_log-20220508:[Mon May 02 19:36:40.078658 2022] [proxy_http:error] [pid 1283248:tid 139735634237184] [client 181.237.234.17:58893] AH01114: HTTP: failed to make connection to backend: localhost, referer: https://invimanmonitor.triara.co/nagiosxi/admin/sshterm.php
ssl_error_log-20220508:[Mon May 02 19:36:44.190668 2022] [proxy:error] [pid 1283248:tid 139734168872704] (111)Connection refused: AH00957: HTTPS: attempt to connect to 127.0.0.1:7878 (localhost) failed
ssl_error_log-20220508:[Mon May 02 19:36:44.190727 2022] [proxy_http:error] [pid 1283248:tid 139734168872704] [client 181.237.234.17:58908] AH01114: HTTP: failed to make connection to backend: localhost, referer: https://invimanmonitor.triara.co/nagiosxi/admin/sshterm.php
ssl_error_log-20220508:[Mon May 02 19:38:08.105642 2022] [proxy:error] [pid 1288227:tid 139735284578048] (111)Connection refused: AH00957: HTTPS: attempt to connect to 127.0.0.1:7878 (localhost) failed
ssl_error_log-20220508:[Mon May 02 19:38:08.105694 2022] [proxy_http:error] [pid 1288227:tid 139735284578048] [client 10.110.0.40:51616] AH01114: HTTP: failed to make connection to backend: localhost
