stderr:"/usr/local/nagios/libexec/check_nna.py", line 159
bcgriffin90
Re: stderr:"/usr/local/nagios/libexec/check_nna.py", line 15
I tried re-adding the NNA Source again via the configuration wizard and the integration is working now. I'm unsure which troubleshooting step resolved the issue, but it appears to be resolved now.
Hi
Thanks for updating us.
I am going to lock this topic so if you have any further issues please use our new ticketing system:
ThanksWe're moving to a new support system!
The Nagios Answer Hub is a place where you can get help with technical questions from our experts. There, you can quickly open tickets and join discussion boards.
Request Nagios Answer Hub access here: https://info.nagios.com/answer-hub-access-new-users
After completing the access form, you will be given access to a portal where new tickets can be created. We will keep the old customer forum sections and ticket system available for current cases to be resolved.
