Disabled Hosts Still Monitored
jbennett
Re: Disabled Hosts Still Monitored
Post by jbennett »
[root@nagiosxivm rw]# ls -l /usr/local/nagios/var/rw/nagios.cmd
prw-rw---- 1 nagios nagcmd 0 Aug 13 14:19 /usr/local/nagios/var/rw/nagios.cmd
[root@nagiosxivm rw]# cat /etc/group|grep nag
nagios:x:500:apache
nagcmd:x:501:
nagioscmd:x:502:
nagiocmd:x:503:nagios,nobody
No, I did not try to recompile outside of the install/upgrade scripts as far as I know. The individual who installed and configured prior to my taking over may have.
So when you restart nagios is it leaving the permissions as:
This is how it is supposed to be.
jbennett
Post by jbennett »
The permissions do remain the same, however, when I try to schedule downtime, or acknowledge a host or service being down, I get the error:
Error: Could not open command file '/usr/local/nagios/var/rw/nagios.cmd' for update!
As stated in my previous post, if I chmod 777 /usr/local/nagios/var/rw/nagios.cmd, I'm able to schedule down-time and to acknowledge without error.
I am not sure why you have all these entries in the /etc/group:
nagios:x:500:apache
nagcmd:x:501:
nagioscmd:x:502:
You should probably have only these:
nagios:x:500:nagios,apache
nagcmd:x:501:nagios,apache
Note that nagios and apache must be added to nagios and nagcmd!
Hope this helps.
