SNMP OID Query for Windows Partition
cccbbb
Re: SNMP OID Query for Windows Partition
Post by cccbbb »
Thanks!
10.3 repo availability is the big issue I think so it is time to upgrade anyway...going to upgrade OpenSuse to 11.0 then 11.4 then upgrading Nagios Core to Nagios XI...
then revisting WMI queries.
I keep you posted
cccbbb
Post by cccbbb »
Had a Perl Mod Issue but resolved it
cccbbb
Post by cccbbb »
Have the WMI checks working using wmic and the check_wmi_plus script.
perl check_wmi_plus.pl --inidir=/usr/lib/nagios/plugins/ -H x.x.x.x -u domain/username -p xxxxxxx -m checkdrivesize -o 1 -3 1
OK - Overall Disk Total=1990.50GB, Used=991.87GB (49.8%), Free=998.63GB (50.2%) |'Overall Disk Space'=991.87GB; 'Overall Disk Utilisation'=49.8%;
but cannot find the right commands for the paritions without drive letters...
perl check_wmi_plus.pl --inidir=/usr/lib/nagios/plugins/ -H x.x.x.x -u domain/username -p xxxxxx -m checkdrivesize -o
Option otheraguments requires an argument
UNKNOWN - Could not find a drive matching '' or the WMI data returned is invalid. Available Drives are E:, F:, G:, I:, K:, L:, M:, O:, Q:
hopefully this isnt that hard
yancy
Post by yancy »
cccbb,
are you able to see the drive statistics using WMIC?
for example:
./wmic -U administrator%password //192.168.5.87 "select * from Win32_LogicalDisk"
Regards,
-Yancy
cccbbb
Post by cccbbb »
yes but once again only partitions using drive letters..
CLASS: Win32_LogicalDisk
Access|Availability|BlockSize|Caption|Compressed|ConfigManagerErrorCode|ConfigManagerUserConfig|CreationClassName|Description|DeviceID|DriveType|ErrorCleared|ErrorDescription|ErrorMethodology|FileSystem|FreeSpace|InstallDate|LastErrorCode|MaximumComponentLength|MediaType|Name|NumberOfBlocks|PNPDeviceID|PowerManagementCapabilities|PowerManagementSupported|ProviderName|Purpose|QuotasDisabled|QuotasIncomplete|QuotasRebuilding|Size|Status|StatusInfo|SupportsDiskQuotas|SupportsFileBasedCompression|SystemCreationClassName|SystemName|VolumeDirty|VolumeName|VolumeSerialNumber
0|0|0|A:|False|0|False|Win32_LogicalDisk|3 1/2 Inch Floppy Drive|A:|2|False|(null)|(null)|(null)|0|(null)|0|0|5|A:|0|(null)|NULL|False|(null)|(null)|False|False|False|0|(null)|0|False|False|Win32_ComputerSystem|VM-EXCH-DAG2|False|(null)|(null)
0|0|0|C:|False|0|False|Win32_LogicalDisk|Local Fixed Disk|C:|3|False|(null)|(null)|NTFS|15701860352|(null)|0|255|12|C:|0|(null)|NULL|False|(null)|(null)|True|False|False|42842714112|(null)|0|True|True|Win32_ComputerSystem|VM-EXCH-DAG2|False||A0CD0F3D
0|0|0|D:|False|0|False|Win32_LogicalDisk|CD-ROM Disc|D:|5|False|(null)|(null)|(null)|0|(null)|0|0|11|D:|0|(null)|NULL|False|(null)|(null)|False|False|False|0|(null)|0|False|False|Win32_ComputerSystem|VM-EXCH-DAG2|False|(null)|(null)
0|0|0|E:|False|0|False|Win32_LogicalDisk|Local Fixed Disk|E:|3|False|(null)|(null)|NTFS|8845971456|(null)|0|255|12|E:|0|(null)|NULL|False|(null)|(null)|True|False|False|10090442752|(null)|0|True|True|Win32_ComputerSystem|VM-EXCH-DAG2|False|Exchange|6C5C9E3B
0|0|0|F:|False|0|False|Win32_LogicalDisk|Local Fixed Disk|F:|3|False|(null)|(null)|NTFS|43302715392|(null)|0|255|12|F:|0|(null)|NULL|False|(null)|(null)|True|False|False|225348354048|(null)|0|True|False|Win32_ComputerSystem|VM-EXCH-DAG2|False|DB1|8CD27768
0|0|0|G:|False|0|False|Win32_LogicalDisk|Local Fixed Disk|G:|3|False|(null)|(null)|NTFS|39090520064|(null)|0|255|12|G:|0|(null)|NULL|False|(null)|(null)|True|False|False|225348354048|(null)|0|True|False|Win32_ComputerSystem|VM-EXCH-DAG2|False|DB2|7CDD7296
0|0|0|I:|False|0|False|Win32_LogicalDisk|Local Fixed Disk|I:|3|False|(null)|(null)|NTFS|28560130048|(null)|0|255|12|I:|0|(null)|NULL|False|(null)|(null)|True|False|False|225348354048|(null)|0|True|False|Win32_ComputerSystem|VM-EXCH-DAG2|False|DB3|CC02777F
0|0|0|K:|False|0|False|Win32_LogicalDisk|Local Fixed Disk|K:|3|False|(null)|(null)|NTFS|16264593408|(null)|0|255|12|K:|0|(null)|NULL|False|(null)|(null)|True|False|False|42812243968|(null)|0|True|False|Win32_ComputerSystem|VM-EXCH-DAG2|False|LOGS1|ACA204FC
0|0|0|L:|False|0|False|Win32_LogicalDisk|Local Fixed Disk|L:|3|False|(null)|(null)|NTFS|40267874304|(null)|0|255|12|L:|0|(null)|NULL|False|(null)|(null)|True|False|False|42812243968|(null)|0|True|False|Win32_ComputerSystem|VM-EXCH-DAG2|False|LOGS2|7CB19E90
0|0|0|M:|False|0|False|Win32_LogicalDisk|Local Fixed Disk|M:|3|False|(null)|(null)|NTFS|816390864896|(null)|0|255|12|M:|0|(null)|NULL|False|(null)|(null)|True|False|False|1288353808384|(null)|0|True|False|Win32_ComputerSystem|VM-EXCH-DAG2|False|Journal|BA1D3A42
0|0|0|O:|False|0|False|Win32_LogicalDisk|Local Fixed Disk|O:|3|False|(null)|(null)|NTFS|73359949824|(null)|0|255|12|O:|0|(null)|NULL|False|(null)|(null)|True|False|False|75025547264|(null)|0|True|False|Win32_ComputerSystem|VM-EXCH-DAG2|False|JALogs|56A9B47A
0|0|0|Q:|False|0|False|Win32_LogicalDisk|Local Fixed Disk|Q:|3|False|(null)|(null)|NTFS|1640906752|(null)|0|255|12|Q:|0|(null)|NULL|False|(null)|(null)|True|False|False|2144333824|(null)|0|True|True|Win32_ComputerSystem|VM-EXCH-DAG2|False|Avamar|72447D83
cccbbb
Post by cccbbb »
Using Win32_Volume does return the partitions in the query but I am not sure how you would retrieve used disk space and warn/critically alert on it....
they are listed under the E:\
from Win32_Volume"
CLASS: Win32_Volume
Access|Automount|Availability|BlockSize|BootVolume|Capacity|Caption|Compressed|ConfigManagerErrorCode|ConfigManagerUserConfig|CreationClassName|Description|DeviceID|DirtyBitSet|DriveLetter|DriveType|ErrorCleared|ErrorDescription|ErrorMethodology|FileSystem|FreeSpace|IndexingEnabled|InstallDate|Label|LastErrorCode|MaximumFileNameLength|Name|NumberOfBlocks|PageFilePresent|PNPDeviceID|PowerManagementCapabilities|PowerManagementSupported|Purpose|QuotasEnabled|QuotasIncomplete|QuotasRebuilding|SerialNumber|Status|StatusInfo|SupportsDiskQuotas|SupportsFileBasedCompression|SystemCreationClassName|SystemName|SystemVolume
0|True|0|4096|False|104853504|\\?\Volume{208d305a-c503-11e0-8410-806e6f6e6963}\|False|0|False|(null)|(null)|\\?\Volume{208d305a-c503-11e0-8410-806e6f6e6963}\|False|(null)|3|False|(null)|(null)|NTFS|75362304|True|(null)|System Reserved|0|255|\\?\Volume{208d305a-c503-11e0-8410-806e6f6e6963}\|0|False|(null)|NULL|False|(null)|False|False|False|2362140965|(null)|0|True|True|(null)|VM-EXCH-DAG2|True
0|True|0|4096|False|10090442752|E:\|False|0|False|(null)|(null)|\\?\Volume{0b353efb-c509-11e0-9ecf-005056a30012}\|False|E:|3|False|(null)|(null)|NTFS|8845578240|True|(null)|Exchange|0|255|E:\|0|False|(null)|NULL|False|(null)|False|False|False|1818009147|(null)|0|True|True|(null)|VM-EXCH-DAG2|False
0|True|0|65536|False|42812243968|K:\|False|0|False|(null)|(null)|\\?\Volume{6be4729e-6543-460b-8d37-c8db00a66430}\|False|K:|3|False|(null)|(null)|NTFS|15901917184|True|(null)|LOGS1|0|255|K:\|0|False|(null)|NULL|False|(null)|False|False|False|2896299260|(null)|0|True|False|(null)|VM-EXCH-DAG2|False
0|True|0|65536|False|42812243968|L:\|False|0|False|(null)|(null)|\\?\Volume{f8de9941-ba94-437f-a74a-5e935c17ffaf}\|False|L:|3|False|(null)|(null)|NTFS|40110850048|True|(null)|LOGS2|0|255|L:\|0|False|(null)|NULL|False|(null)|False|False|False|2092015248|(null)|0|True|False|(null)|VM-EXCH-DAG2|False
0|True|0|65536|False|225348354048|F:\|False|0|False|(null)|(null)|\\?\Volume{7e4eb5e5-8b77-4b97-9df9-8b1d11805f25}\|False|F:|3|False|(null)|(null)|NTFS|43167186944|True|(null)|DB1|0|255|F:\|0|False|(null)|NULL|False|(null)|False|False|False|2362603368|(null)|0|True|False|(null)|VM-EXCH-DAG2|False
0|True|0|65536|False|225348354048|G:\|False|0|False|(null)|(null)|\\?\Volume{b40149bf-63ff-46b3-997e-aa5140b33842}\|False|G:|3|False|(null)|(null)|NTFS|39090913280|True|(null)|DB2|0|255|G:\|0|False|(null)|NULL|False|(null)|False|False|False|2094887574|(null)|0|True|False|(null)|VM-EXCH-DAG2|False
0|True|0|65536|False|225348354048|I:\|False|0|False|(null)|(null)|\\?\Volume{477d6f0a-a4d2-4b15-989f-ced1c9bd610e}\|False|I:|3|False|(null)|(null)|NTFS|28558098432|True|(null)|DB3|0|255|I:\|0|False|(null)|NULL|False|(null)|False|False|False|3422713727|(null)|0|True|False|(null)|VM-EXCH-DAG2|False
0|True|0|65536|False|225348354048|E:\Database\DB4\|False|0|False|(null)|(null)|\\?\Volume{f7e6a6ca-7818-492f-9029-4751f6e47423}\|False|(null)|3|False|(null)|(null)|NTFS|22919643136|True|(null)|DB4-P|0|255|E:\Database\DB4\|0|False|(null)|NULL|False|(null)|False|False|False|3300624655|(null)|0|True|False|(null)|VM-EXCH-DAG2|False
0|True|0|65536|False|1288353808384|M:\|False|0|False|(null)|(null)|\\?\Volume{eced3aa7-60a9-4ec8-878a-f32461709d5a}\|False|M:|3|False|(null)|(null)|NTFS|816248520704|True|(null)|Journal|0|255|M:\|0|False|(null)|NULL|False|(null)|False|False|False|3122477634|(null)|0|True|False|(null)|VM-EXCH-DAG2|False
0|True|0|65536|False|225482571776|E:\Database\TempStore\|False|0|False|(null)|(null)|\\?\Volume{353677c7-9c86-11e1-90f3-005056a3001a}\|False|(null)|3|False|(null)|(null)|NTFS|225387151360|True|(null)|MigrationTempStore|0|255|E:\Database\TempStore\|0|False|(null)|NULL|False|(null)|False|False|False|1925025851|(null)|0|True|False|(null)|VM-EXCH-DAG2|False
0|True|0|65536|False|75025547264|O:\|False|0|False|(null)|(null)|\\?\Volume{5d33c74c-6037-4f99-a3a4-cf49a018a5ec}\|False|O:|3|False|(null)|(null)|NTFS|73174351872|True|(null)|JALogs|0|255|O:\|0|False|(null)|NULL|False|(null)|False|False|False|1453962362|(null)|0|True|False|(null)|VM-EXCH-DAG2|False
0|True|0|4096|False|2144333824|Q:\|False|0|False|(null)|(null)|\\?\Volume{8ca3e6b2-c76b-11e0-82ad-005056a3001a}\|False|Q:|3|False|(null)|(null)|NTFS|1640906752|True|(null)|Avamar|0|255|Q:\|0|False|(null)|NULL|False|(null)|False|False|False|1917091203|(null)|0|True|True|(null)|VM-EXCH-DAG2|False
0|True|0|4096|False|161058123776|E:\Database\Archive\|False|0|False|(null)|(null)|\\?\Volume{354f48a1-08cb-11e1-82ad-005056a3001a}\|False|(null)|3|False|(null)|(null)|NTFS|35455455232|False|(null)|ArchiveDB-P|0|255|E:\Database\Archive\|0|False|(null)|NULL|False|(null)|False|False|False|1183236009|(null)|0|True|True|(null)|VM-EXCH-DAG2|False
[color=#000FF]0|True|0|65536|False|37577752576|E:\Logs\LOGS3\|False|0|False|(null)|(null)|\\?\Volume{353673ad-9c86-11e1-90f3-005056a3001a}\|False|(null)|3|False|(null)|(null)|NTFS|34607529984|True|(null)|LOGS3-S|0|255|E:\Logs\LOGS3\|0|False|(null)|NULL|False|(null)|False|False|False|2224143456|(null)|0|True|False|(null)|VM-EXCH-DAG2|False[/color]
0|True|0|65536|False|397281263616|E:\Database\DB6\|False|0|False|(null)|(null)|\\?\Volume{b1ba57ba-4a3b-11e1-90f3-005056a3001a}\|False|(null)|3|False|(null)|(null)|NTFS|152580521984|True|(null)|DB6-S|0|255|E:\Database\DB6\|0|False|(null)|NULL|False|(null)|False|False|False|2558053893|(null)|0|True|False|(null)|VM-EXCH-DAG2|False[/color][/color]
0|True|0|4096|True|42842714112|C:\|False|0|False|(null)|(null)|\\?\Volume{208d305b-c503-11e0-8410-806e6f6e6963}\|False|C:|3|False|(null)|(null)|NTFS|15701778432|True|(null)|(null)|0|255|C:\|0|True|(null)|NULL|False|(null)|False|False|False|2697793341|(null)|0|True|True|(null)|VM-EXCH-DAG2|False
0|True|0|0|False|0|D:\|False|0|False|(null)|(null)|\\?\Volume{208d3060-c503-11e0-8410-806e6f6e6963}\|False|D:|5|False|(null)|(null)|(null)|0|False|(null)|(null)|0|0|D:\|0|False|(null)|NULL|False|(null)|False|False|False|0|(null)|0|False|False|(null)|VM-EXCH-DAG2|False
yancy
Post by yancy »
cccbb,
take a look at check_wmi_plus.ini. A list of predefined checks are listed, where the header name is the WMI check.
for example, the sectio [info listsoftware2003] can be ran like:
./check_wmi_plus.pl -H <ip> -u <user> -p <password> -m "info listsoftware2003"
you can define your own definitions by either creating a different .ini file or adding to check_wmi_plus.ini
http://www.edcint.co.nz/checkwmiplus/?q=node/78
I can put together an example if your still not finding the information you need.
Regards,
-Yancy
