Nagios and NSCA (for Munin)
mguthrie
Re: Nagios and NSCA (for Munin)
Post by mguthrie »
Is SElinux enabled on the Munin machine?
gshergill
Post by gshergill »
Hi mguthrie,
How would I go about checking/enabling this please?
Thank you.
Kind Regards,
gshergill
run the following to check
sestatus
gshergill
Post by gshergill »
Hi guys,
Sorry for the late response, have been on holiday and just got back in.
I ran the sestatus and recieved the following;
root@muninnagios:~# sestatus
The program 'sestatus' is currently not installed.  You can install it by typing:
apt-get install policycoreutils
After running apt-get install policycoreutils I re-ran the command above and received the following;
SELinux status:                 disabled
What exactly is SELinux used for? I'll looking online for how to enable it, but does it need to be enabled in a specific way?
Thank you.
Kind Regards,
gshergill
gshergill
Post by gshergill »
Hi guys,
The following is the config file for SELinux (/etc/selinux/config);
# This file controls the state of SELinux on the system.
# SELINUX= can take one of these three values:
# enforcing - SELinux security policy is enforced.
# permissive - SELinux prints warnings instead of enforcing.
# disabled - No SELinux policy is loaded.
SELINUX=permissive
# SELINUXTYPE= can take one of these two values:
# default - equivalent to the old strict and targeted policies
# mls - Multi-Level Security (for military and educational use)
# src - Custom policy built from source
SELINUXTYPE=default
# SETLOCALDEFS= Check local definition changes
SETLOCALDEFS=0
Thank you again.
Kind Regards,
gshergill
mguthrie
Post by mguthrie »
Try setting:
SELINUX=disabled
In the selinux config. And then running:
setenforce 0
gshergill
Post by gshergill »
Hi mguthrie,
The following is the output from the setenforce command;
root@muninnagios:~# setenforce 0
setenforce: SELinux is disabled
The following is the output of the send_nsca command on the Nagios Machine to the Munin machine;
[root@nagiosxi ~]# /usr/local/nagios/libexec/send_nsca -H 192.168.3.82 -c /usr/local/nagios/etc/send_nsca.cfg
Connection refused by host
Error: Could not connect to host 192.168.3.82 on port 5667
Still the same error of connection refused.
And from the Munin Machine;
root@muninnagios:~# /usr/sbin/send_nsca -H localhost -c /etc/send_nsca.cfg
Error: Could not connect to host localhost on port 5667
Thanks.
Kind Regards,
gshergill
mguthrie
Post by mguthrie »
Pretty sure you're still getting blocked by the firewall. I didn't see nsca on the list of open ports. Add the following line to /etc/sysconfig/iptables and then restart the iptables service.
-A INPUT -p tcp -m state --state NEW -m tcp --dport 5667 -j ACCEPT
gshergill
Post by gshergill »
Hi mguthrie,
On the Nagios XI machine, the following is already in the iptables;
#-A INPUT -m state --state NEW -m tcp -p tcp --dport 5667 -j ACCEPT
However, I added your line instead.
The Munin machine had no sysconfig folder, nor anywhere to edit the iptables.
Running the commands;
aptitude install sysconftool
Hasn't added the directory for sysconfig.
And trying to install the iptables results in the following;
root@muninnagios:~# aptitude install iptables
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
I'm guessing that's the issue? Being unable to edit the iptables on the Munin machine means there's nothing to allow the port?
Thank you.
Kind Regards,
gshergill
you should be able to run the following command
iptables -A INPUT -p tcp -m state --state NEW -m tcp --dport 5667 -j ACCEPT
