Upgrading is pretty straight forward
http://library.nagios.com/library/produ ... -nagios-xi
Quick Find with more character not working
Re: Quick Find with more character not working
Dear Experts,
i have tested on 2012R1.7 and it's working. you can close and lock this topic.
Best Regards,
Yusuf
Best Regards,
Yusuf
Zajil NMS
Dear Experts,
ignore my previous message, we are still having same issue with updated version of XI which is 2012R1.8 " unable to search with specific character which is '0171:tec_jnpr_1:' "
kindly have a look and update me asap. also where i can see the changelog of old to new XI
Best Regards,
Best Regards,
Zajil NMS
Dear Experts,
just now observed one thing when i did quick search with following format it's work. instead of ":" i put "_" in quick find and gave me the correct result.
Best Regards
Best Regards
Zajil NMS
So it was working properly on 1.7 but not 1.8 since you upgraded again? Looking into this now, you can view the change logs by visiting:
http://assets.nagios.com/downloads/nagi ... S-2012.TXT
Though some small changes may not be logged.
