monitoring linux disks
jeremy.garman
Re: monitoring linux disks
Post by jeremy.garman »
Phew!! It works!! I did a combination of both of your suggestions (abrist and gshergill), including reconfiguring with the --command-args switch.
LOL now I need to very quick summarize what steps I took in order to apply that fix to all my other linux servers!
You guys rock! Thanks so much!!
abrist
Red Shirt
Post by abrist »
Brilliant! Glad we could help! The command-args recompile is probably the key piece. Best of luck.
