Not able to generate report using NAT IP
wiproltdwiv
Re: Not able to generate report using NAT IP
Post by wiproltdwiv »
hi,
i edited php.ini resource limits.
still we had same issue.. attached screenshot for your ref.
If 172.29.70.37 is the IP you connect to through the NAT it should go in the External URL on Admin -> Manage System Config
And the Program URL: needs to be set to something that the machine can use in the internal network to access.
Also, it may be necessary to add an entry in /etc/hosts for emsnagios1.co-opbank.co.in so the machine can access itself with this configuration
