Problems: CHECK_NRPE: Socket timeout after 10 seconds.
psyllex
Re: Problems: CHECK_NRPE: Socket timeout after 10 seconds.
Post by psyllex »
yes, I assumed that as well. But when I tried to run them both....it failed. But there were many factors I was changing around at that point so I am going to go back in and try it again.
abrist
Red Shirt
Post by abrist »
great, keeps us informed of your progress.
psyllex
Post by psyllex »
Alright! I did as you suggested and merely changed the name on the "check_zombie_procs" and "check_local_procs" to "check_procs" on both and it seems to be running fine. I don't know exactly what type of data this is giving me, I assume aggregate data between the two commands.
abrist
Red Shirt
Post by abrist »
I may not have been clear enough. The names should be different in the nrpe.cfg (the command in the []). They should coincide with the service definitions commands on the nagios server. Could you post your service/command definition for the checks from the nagios server and your nrpe.cfg from the remote host in a code wrap?
psyllex
Post by psyllex »
abrist wrote:I may not have been clear enough. The names should be different in the nrpe.cfg (the command in the []). They should coincide with the service definitions commands on the nagios server. Could you post your service/command definition for the checks from the nagios server and your nrpe.cfg from the remote host in a code wrap?
Ok...my misunderstanding. In the post about 5 posts ago I showed the commands from nrpe.cfg. The problem was I had "check_total_procs" and "check_zombie_procs". The commands were both correct, I just needed to name them properly in the nrpe.cfg.
The commands are on a airgapped network and unfortunately I don't have time to type them all out right now. But I understand what you're saying. I'll post my commands later when I'm a bit more free.
Post by slansing »
Thanks for keeping us updated. We will be able to help more when we see how you have them defined and are using them.
psyllex
Post by psyllex »
slansing wrote:Thanks for keeping us updated. We will be able to help more when we see how you have them defined and are using them.
This is in another posting too so probably only respond to one. Here are my 3 nrpe.cfg files.
Server A
# Sample NRPE Config File
# Written by: Ethan Galstad ([email protected])
# Last Modified: 11-23-2007
# NOTES:
# This is a sample configuration file for the NRPE daemon.  It needs to be
# located on the remote host that is running the NRPE daemon, not the host
# from which the check_nrpe client is being executed.
# LOG FACILITY
# The syslog facility that should be used for logging purposes.
log_facility=daemon
# PID FILE
# The name of the file in which the NRPE daemon should write it's process ID
# number.  The file is only written if the NRPE daemon is started by the root
# user and is running in standalone mode.
pid_file=/var/run/nrpe.pid
# PORT NUMBER
# Port number we should wait for connections on.
# NOTE: This must be a non-priviledged port (i.e. > 1024).
# NOTE: This option is ignored if NRPE is running under either inetd or xinetd
server_port=5666
# SERVER ADDRESS
# Address that nrpe should bind to in case there are more than one interface
# and you do not want nrpe to bind on all interfaces.
server_address=10.10.0.100
# NRPE USER
# This determines the effective user that the NRPE daemon should run as.
nrpe_user=nagios
# NRPE GROUP
# This determines the effective group that the NRPE daemon should run as.
nrpe_group=nagios
# ALLOWED HOST ADDRESSES
# This is an optional comma-delimited list of IP address or hostnames
# that are allowed to talk to the NRPE daemon. Network addresses with a bit mask
# (i.e. 192.168.1.0/24) are also supported. Hostname wildcards are not currently
# supported.
# Note: The daemon only does rudimentary checking of the client's IP
# address.  I would highly recommend adding entries in your /etc/hosts.allow
# file to allow only the specified host to connect to the port
# you are running this daemon on.
allowed_hosts=127.0.0.1 10.10.0.100
# COMMAND ARGUMENT PROCESSING
# This option determines whether or not the NRPE daemon will allow clients
# to specify arguments to commands that are executed.  This option only works
# if the daemon was configured with the --enable-command-args configure script
# option.
# *** ENABLING THIS OPTION IS A SECURITY RISK! ***
# Read the SECURITY file for information on some of the security implications
# of enabling this variable.
# Values: 0=do not allow arguments, 1=allow command arguments
dont_blame_nrpe=1
# COMMAND PREFIX
# This option allows you to prefix all commands with a user-defined string.
# A space is automatically added between the specified prefix string and the
# command line from the command definition.
# *** THIS EXAMPLE MAY POSE A POTENTIAL SECURITY RISK, SO USE WITH CAUTION! ***
# Usage scenario:
# Execute restricted commmands using sudo.  For this to work, you need to add
# the nagios user to your /etc/sudoers.  An example entry for alllowing
# execution of the plugins from might be:
# nagios          ALL=(ALL) NOPASSWD: /usr/lib/nagios/plugins/
# This lets the nagios user run all commands in that directory (and only them)
# without asking for a password.  If you do this, make sure you don't give
# random users write access to that directory or its contents!
# command_prefix=/usr/bin/sudo
# DEBUGGING OPTION
# This option determines whether or not debugging messages are logged to the
# syslog facility.
# Values: 0=debugging off, 1=debugging on
debug=0
# COMMAND TIMEOUT
# This specifies the maximum number of seconds that the NRPE daemon will
# allow plugins to finish executing before killing them off.
command_timeout=60
# CONNECTION TIMEOUT
# wait for a connection to be established before exiting. This is sometimes
# seen where a network problem stops the SSL being established even though
# all network sessions are connected. This causes the nrpe daemons to
# accumulate, eating system resources. Do not set this too low.
connection_timeout=300
# WEEK RANDOM SEED OPTION
# This directive allows you to use SSL even if your system does not have
# a /dev/random or /dev/urandom (on purpose or because the necessary patches
# were not applied). The random number generator will be seeded from a file
# which is either a file pointed to by the environment valiable $RANDFILE
# or $HOME/.rnd. If neither exists, the pseudo random number generator will
# be initialized and a warning will be issued.
# Values: 0=only seed from /dev/[u]random, 1=also seed from weak randomness
#allow_weak_random_seed=1
# INCLUDE CONFIG FILE
# This directive allows you to include definitions from an external config file.
#include=<somefile.cfg>
# INCLUDE CONFIG DIRECTORY
# This directive allows you to include definitions from config files (with a
# .cfg extension) in one or more directories (with recursion).
#include_dir=<somedirectory>
#include_dir=<someotherdirectory>
# COMMAND DEFINITIONS
# Command definitions that this daemon will run.  Definitions
# are in the following format:
# command[<command_name>]=<command_line>
# When the daemon receives a request to return the results of <command_name>
# it will execute the command specified by the <command_line> argument.
# Unlike Nagios, the command line cannot contain macros - it must be
# typed exactly as it should be executed.
# Note: Any plugins that are used in the command lines must reside
# on the machine that this daemon is running on!  The examples below
# assume that you have plugins installed in a /usr/local/nagios/libexec
# directory.  Also note that you will have to modify the definitions below
# to match the argument format the plugins expect.  Remember, these are
# examples only!
# The following examples use hardcoded command arguments...
command[check_hda1]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/sda1
command[check_procs]=/usr/local/nagios/libexec/check_procs -w 5 -c 10 -s
command[check_procs]=/usr/local/nagios/libexec/check_procs -w 200 -c 250
command[check_ping]=/usr/local/nagios/libexec/check_ping -n -H 10.10.0.102 -w 750.0,80% -c 1500.0,9\0%
command[check_udp]=/usr/local/nagios/libexec/check_udp -H 10.10.0.102 -p 199 -s 'send' -e ''
command[check_tcp]=/usr/local/nagios/libexec/check_tcp -H 10.10.0.102 -p 21 -s 'send' -e ''
#command[check_ping2]=/usr/local/nagios/libexec/check_ping2 -n -H 10.10.0.103 -w 750.0,80% -c 1500.0,90%
# The following examples allow user-supplied arguments and can
# only be used if the NRPE daemon was compiled with support for
# command arguments *AND* the dont_blame_nrpe directive in this
# config file is set to '1'.  This poses a potential security risk, so
# make sure you read the SECURITY file before doing this.
#command[check_users]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$
#command[check_load]=/usr/local/nagios/libexec/check_load -w $ARG1$ -c $ARG2$
#command[check_disk]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
#command[check_procs]=/usr/local/nagios/libexec/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
Server B
# NOTES:
# LOG FACILITY
log_facility=daemon
# PID FILE
# PORT NUMBER
server_port=5666
# SERVER ADDRESS
# NRPE USER
nrpe_user=nagios
# NRPE GROUP
nrpe_group=nagios
# supported.
allowed_hosts=127.0.0.1 10.0.0.100
# option.
dont_blame_nrpe=1
# COMMAND PREFIX
# Usage scenario:
# DEBUGGING OPTION
# syslog facility.
debug=0
# COMMAND TIMEOUT
command_timeout=60
# examples only!
command[check_hda1]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/\
sda1
command[check_ping]=/usr/local/nagios/libexec/check_ping -n -H 10.10.0.103 -w 7\
command[check_udp]=/usr/local/nagios/libexec/check_udp -H 10.10.0.103 -p 199 -s\
 'send' -e ''
command[check_tcp]=/usr/local/nagios/libexec/check_tcp -H 10.10.0.103 -p 21 -s \
'send' -e ''
Nagios Server
# NOTES:
# LOG FACILITY
log_facility=daemon
# PID FILE
# PORT NUMBER
server_port=5666
# SERVER ADDRESS
#server_address=127.0.0.1
# NRPE USER
nrpe_user=nagios
# NRPE GROUP
nrpe_group=nagios
# supported.
# option.
dont_blame_nrpe=1
# COMMAND PREFIX
# Usage scenario:
# DEBUGGING OPTION
# syslog facility.
debug=0
# COMMAND TIMEOUT
command_timeout=60
# examples only!
command[check_procs]=/usr/local/nagios/libexec/check_procs -w 5 -c 10 -s Z
command[check_procs]=/usr/local/nagios/libexec/check_procs -w 150 -c 200
command[check_ping]=/usr/local/nagios/libexec/check_ping -n -H localhost -w 750.0,80% -c 1500,90%
command[check_udp]=/usr/local/nagios/libexec/check_udp -n -H 10.10.0.102 -p 199 -s 'send' -e ''
command[check_tcp]=/usr/local/nagios/libexec/check_tcp -n -H 10.10.0.102 -p 199 -s 'send' -e ''
command[check_udp]=/usr/local/nagios/libexec/check_udp -n -H 10.10.0.103 -p 199\
 -s 'send' -e ''
command[check_tcp]=/usr/local/nagios/libexec/check_tcp -n -H 10.10.0.103 -p 199 -s 'send' -e ''
Thanks fopr all the help
abrist
Red Shirt
Post by abrist »
Lets handle this in the other thread as both of these threads deal with nrpe errors that are quite common when setting up nrpe, and often related. Can I lock this thread?
psyllex
Post by psyllex »
Yes sir.
