Apparently the wheel was not round enough. Sorry for the tribbles...er...troubles./var/log/messages has been deleted from Natty.
You can find the same info in /var/log/syslog. Note that everything logged to messages was also logged to syslog
New NRPE error - error receiving data from daemon
Re: New NRPE error - error receiving data from daemon
I found on ubuntu's site:
Yes I found the common file in /etc/nagios/nrpe.d. Was I supposed to do something with this?slansing wrote:Did you find common.cfg at:
This is where the agent installs it to, assuming you used our documentation.Code: Select all
/etc/nagios/nrpe.d/common.cfg
Here's my syslog:
I noticed it said that line 13 in hosts.allowed was too long. Not sure what that's about all I have in there is the ipaddress.
Feb 28 13:53:21 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 13:53:21 ntop[1476]: last message repeated 2 times
Feb 28 13:53:21 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 13:53:21 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (13098->8232)
Feb 28 13:53:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 13:53:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 13:53:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 13:53:33 tribbleNet1-3 nrpe[22022]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:53:33 tribbleNet1-3 nrpe[22022]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:53:33 tribbleNet1-3 nrpe[22022]: Error: Could not complete SSL handshake. 1
Feb 28 13:53:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 13:54:05 tribbleNet1-3 nrpe[22037]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:54:05 tribbleNet1-3 nrpe[22037]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:54:05 tribbleNet1-3 nrpe[22037]: Error: Could not complete SSL handshake. 1
Feb 28 13:54:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 13:54:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 13:54:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 13:55:01 snmpd[1661]: last message repeated 3 times
Feb 28 13:55:01 tribbleNet1-3 CRON[22069]: (www-data) CMD (php /usr/share/cacti/site/poller.php >/dev/null 2>/var/log/cacti/poller-error.log)
Feb 28 13:55:08 tribbleNet1-3 nrpe[22073]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:55:08 tribbleNet1-3 nrpe[22073]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:55:08 tribbleNet1-3 nrpe[22073]: Error: Could not complete SSL handshake. 1
Feb 28 13:55:21 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 13:55:21 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 13:55:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 13:55:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 13:55:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 13:55:40 tribbleNet1-3 nrpe[22087]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:55:40 tribbleNet1-3 nrpe[22087]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:55:40 tribbleNet1-3 nrpe[22087]: Error: Could not complete SSL handshake. 1
Feb 28 13:55:52 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 13:55:52 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 13:55:52 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 13:55:52 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 13:55:52 ntop[1476]: last message repeated 2 times
Feb 28 13:55:52 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (27578->8232)
Feb 28 13:55:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 13:56:11 tribbleNet1-3 nrpe[22100]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:56:11 tribbleNet1-3 nrpe[22100]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:56:11 tribbleNet1-3 nrpe[22100]: Error: Could not complete SSL handshake. 1
Feb 28 13:56:22 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 13:56:22 ntop[1476]: last message repeated 5 times
Feb 28 13:56:22 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 13:56:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 13:56:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 13:56:27 tribbleNet1-3 nrpe[22116]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:56:27 tribbleNet1-3 nrpe[22116]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:56:27 tribbleNet1-3 nrpe[22116]: Error: Could not complete SSL handshake. 1
Feb 28 13:56:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 13:56:43 tribbleNet1-3 nrpe[22120]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:56:43 tribbleNet1-3 nrpe[22120]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:56:43 tribbleNet1-3 nrpe[22120]: Error: Could not complete SSL handshake. 1
Feb 28 13:56:52 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 13:56:52 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 13:56:52 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 13:56:52 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (13098->8232)
Feb 28 13:56:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 13:56:59 tribbleNet1-3 nrpe[22133]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:56:59 tribbleNet1-3 nrpe[22133]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:56:59 tribbleNet1-3 nrpe[22133]: Error: Could not complete SSL handshake. 1
Feb 28 13:57:22 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 13:57:22 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 13:57:22 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 13:57:22 ntop[1476]: last message repeated 3 times
Feb 28 13:57:22 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (14546->8232)
Feb 28 13:57:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 13:57:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 13:57:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 13:57:30 tribbleNet1-3 nrpe[22145]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:57:30 tribbleNet1-3 nrpe[22145]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:57:30 tribbleNet1-3 nrpe[22145]: Error: Could not complete SSL handshake. 1
Feb 28 13:57:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 13:58:03 tribbleNet1-3 nrpe[22175]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:58:03 tribbleNet1-3 nrpe[22175]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:58:03 tribbleNet1-3 nrpe[22175]: Error: Could not complete SSL handshake. 1
Feb 28 13:58:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 13:58:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 13:58:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 13:58:33 tribbleNet1-3 nrpe[22195]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:58:33 tribbleNet1-3 nrpe[22195]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:58:33 tribbleNet1-3 nrpe[22195]: Error: Could not complete SSL handshake. 1
Feb 28 13:58:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 13:59:05 tribbleNet1-3 nrpe[22208]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 13:59:05 tribbleNet1-3 nrpe[22208]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 13:59:05 tribbleNet1-3 nrpe[22208]: Error: Could not complete SSL handshake. 1
Feb 28 13:59:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 13:59:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 13:59:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:00:01 snmpd[1661]: last message repeated 3 times
Feb 28 14:00:01 tribbleNet1-3 CRON[22242]: (www-data) CMD (php /usr/share/cacti/site/poller.php >/dev/null 2>/var/log/cacti/poller-error.log)
Feb 28 14:00:08 tribbleNet1-3 nrpe[22246]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:00:08 tribbleNet1-3 nrpe[22246]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:00:08 tribbleNet1-3 nrpe[22246]: Error: Could not complete SSL handshake. 1
Feb 28 14:00:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:00:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:00:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:00:40 tribbleNet1-3 nrpe[22258]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:00:40 tribbleNet1-3 nrpe[22258]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:00:40 tribbleNet1-3 nrpe[22258]: Error: Could not complete SSL handshake. 1
Feb 28 14:00:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:01:11 tribbleNet1-3 nrpe[22272]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:01:11 tribbleNet1-3 nrpe[22272]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:01:11 tribbleNet1-3 nrpe[22272]: Error: Could not complete SSL handshake. 1
Feb 28 14:01:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:01:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:01:27 tribbleNet1-3 nrpe[22281]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:01:27 tribbleNet1-3 nrpe[22281]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:01:27 tribbleNet1-3 nrpe[22281]: Error: Could not complete SSL handshake. 1
Feb 28 14:01:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:01:43 tribbleNet1-3 nrpe[22290]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:01:43 tribbleNet1-3 nrpe[22290]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:01:43 tribbleNet1-3 nrpe[22290]: Error: Could not complete SSL handshake. 1
Feb 28 14:01:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:01:59 tribbleNet1-3 nrpe[22306]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:01:59 tribbleNet1-3 nrpe[22306]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:01:59 tribbleNet1-3 nrpe[22306]: Error: Could not complete SSL handshake. 1
Feb 28 14:02:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:02:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:02:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:02:28 tribbleNet1-3 nrpe[21945]: Caught SIGTERM - shutting down...
Feb 28 14:02:28 tribbleNet1-3 nrpe[21945]: Daemon shutdown
Feb 28 14:02:30 tribbleNet1-3 nrpe[22346]: Starting up daemon
Feb 28 14:02:30 tribbleNet1-3 nrpe[22346]: Warning: Daemon is configured to accept command arguments from clients!
Feb 28 14:02:30 tribbleNet1-3 nrpe[22346]: Listening for connections on port 5666
Feb 28 14:02:30 tribbleNet1-3 nrpe[22346]: Allowing connections from: 10.10.0.31
Feb 28 14:02:30 tribbleNet1-3 nrpe[22355]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:02:30 tribbleNet1-3 nrpe[22355]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:02:30 tribbleNet1-3 nrpe[22355]: Error: Could not complete SSL handshake. 1
Feb 28 14:02:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:03:03 tribbleNet1-3 nrpe[22381]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:03:03 tribbleNet1-3 nrpe[22381]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:03:03 tribbleNet1-3 nrpe[22381]: Error: Could not complete SSL handshake. 1
Feb 28 14:03:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:03:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:03:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:03:33 tribbleNet1-3 nrpe[22401]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:03:33 tribbleNet1-3 nrpe[22401]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:03:33 tribbleNet1-3 nrpe[22401]: Error: Could not complete SSL handshake. 1
Feb 28 14:03:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:04:05 tribbleNet1-3 nrpe[22420]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:04:05 tribbleNet1-3 nrpe[22420]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:04:05 tribbleNet1-3 nrpe[22420]: Error: Could not complete SSL handshake. 1
Feb 28 14:04:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:04:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:04:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:05:01 snmpd[1661]: last message repeated 3 times
Feb 28 14:05:01 tribbleNet1-3 CRON[22450]: (www-data) CMD (php /usr/share/cacti/site/poller.php >/dev/null 2>/var/log/cacti/poller-error.log)
Feb 28 14:05:08 tribbleNet1-3 nrpe[22456]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:05:08 tribbleNet1-3 nrpe[22456]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:05:08 tribbleNet1-3 nrpe[22456]: Error: Could not complete SSL handshake. 1
Feb 28 14:05:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:05:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:05:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:05:40 tribbleNet1-3 nrpe[22472]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:05:40 tribbleNet1-3 nrpe[22472]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:05:40 tribbleNet1-3 nrpe[22472]: Error: Could not complete SSL handshake. 1
Feb 28 14:05:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:06:11 tribbleNet1-3 nrpe[22486]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:06:11 tribbleNet1-3 nrpe[22486]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:06:11 tribbleNet1-3 nrpe[22486]: Error: Could not complete SSL handshake. 1
Feb 28 14:06:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:06:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:06:27 tribbleNet1-3 nrpe[22500]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:06:27 tribbleNet1-3 nrpe[22500]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:06:27 tribbleNet1-3 nrpe[22500]: Error: Could not complete SSL handshake. 1
Feb 28 14:06:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:06:43 tribbleNet1-3 nrpe[22504]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:06:43 tribbleNet1-3 nrpe[22504]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:06:43 tribbleNet1-3 nrpe[22504]: Error: Could not complete SSL handshake. 1
Feb 28 14:06:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:06:59 tribbleNet1-3 nrpe[22524]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:06:59 tribbleNet1-3 nrpe[22524]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:06:59 tribbleNet1-3 nrpe[22524]: Error: Could not complete SSL handshake. 1
Feb 28 14:07:23 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 14:07:23 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 14:07:23 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 14:07:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:07:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:07:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:07:30 tribbleNet1-3 nrpe[22545]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:07:30 tribbleNet1-3 nrpe[22545]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:07:30 tribbleNet1-3 nrpe[22545]: Error: Could not complete SSL handshake. 1
Feb 28 14:07:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:08:03 tribbleNet1-3 nrpe[22572]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:08:03 tribbleNet1-3 nrpe[22572]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:08:03 tribbleNet1-3 nrpe[22572]: Error: Could not complete SSL handshake. 1
Feb 28 14:08:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:08:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:08:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:08:33 tribbleNet1-3 nrpe[22594]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:08:33 tribbleNet1-3 nrpe[22594]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:08:33 tribbleNet1-3 nrpe[22594]: Error: Could not complete SSL handshake. 1
Feb 28 14:08:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:09:01 tribbleNet1-3 CRON[22607]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mindepth 1 -maxdepth 1 -type f -cmin +$(/usr/lib/php5/maxlifetime) ! -execdir fuser -s {} 2>/dev/null \; -delete)
Feb 28 14:09:05 tribbleNet1-3 nrpe[22614]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:09:05 tribbleNet1-3 nrpe[22614]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:09:05 tribbleNet1-3 nrpe[22614]: Error: Could not complete SSL handshake. 1
Feb 28 14:09:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:09:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:09:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:10:01 snmpd[1661]: last message repeated 3 times
Feb 28 14:10:01 tribbleNet1-3 CRON[22645]: (www-data) CMD (php /usr/share/cacti/site/poller.php >/dev/null 2>/var/log/cacti/poller-error.log)
Feb 28 14:10:08 tribbleNet1-3 nrpe[22649]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:10:08 tribbleNet1-3 nrpe[22649]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:10:08 tribbleNet1-3 nrpe[22649]: Error: Could not complete SSL handshake. 1
Feb 28 14:10:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:10:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:10:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:10:40 tribbleNet1-3 nrpe[22665]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:10:40 tribbleNet1-3 nrpe[22665]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:10:40 tribbleNet1-3 nrpe[22665]: Error: Could not complete SSL handshake. 1
Feb 28 14:10:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:11:11 tribbleNet1-3 nrpe[22679]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:11:11 tribbleNet1-3 nrpe[22679]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:11:11 tribbleNet1-3 nrpe[22679]: Error: Could not complete SSL handshake. 1
Feb 28 14:11:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:11:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:11:27 tribbleNet1-3 nrpe[22690]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:11:27 tribbleNet1-3 nrpe[22690]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:11:27 tribbleNet1-3 nrpe[22690]: Error: Could not complete SSL handshake. 1
Feb 28 14:11:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:11:43 tribbleNet1-3 nrpe[22694]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:11:43 tribbleNet1-3 nrpe[22694]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:11:43 tribbleNet1-3 nrpe[22694]: Error: Could not complete SSL handshake. 1
Feb 28 14:11:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:11:59 tribbleNet1-3 nrpe[22719]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:11:59 tribbleNet1-3 nrpe[22719]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:11:59 tribbleNet1-3 nrpe[22719]: Error: Could not complete SSL handshake. 1
Feb 28 14:12:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:12:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:12:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:12:30 tribbleNet1-3 nrpe[22740]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:12:30 tribbleNet1-3 nrpe[22740]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:12:30 tribbleNet1-3 nrpe[22740]: Error: Could not complete SSL handshake. 1
Feb 28 14:12:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:13:03 tribbleNet1-3 nrpe[22766]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:13:03 tribbleNet1-3 nrpe[22766]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:13:03 tribbleNet1-3 nrpe[22766]: Error: Could not complete SSL handshake. 1
Feb 28 14:13:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:13:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:13:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:13:33 tribbleNet1-3 nrpe[22786]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:13:33 tribbleNet1-3 nrpe[22786]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:13:33 tribbleNet1-3 nrpe[22786]: Error: Could not complete SSL handshake. 1
Feb 28 14:13:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:14:05 tribbleNet1-3 nrpe[22802]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:14:05 tribbleNet1-3 nrpe[22802]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:14:05 tribbleNet1-3 nrpe[22802]: Error: Could not complete SSL handshake. 1
Feb 28 14:14:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:14:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:14:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:15:01 snmpd[1661]: last message repeated 3 times
Feb 28 14:15:01 tribbleNet1-3 CRON[22830]: (www-data) CMD (php /usr/share/cacti/site/poller.php >/dev/null 2>/var/log/cacti/poller-error.log)
Feb 28 14:15:08 tribbleNet1-3 nrpe[22834]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:15:08 tribbleNet1-3 nrpe[22834]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:15:08 tribbleNet1-3 nrpe[22834]: Error: Could not complete SSL handshake. 1
Feb 28 14:15:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:15:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:15:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:15:40 tribbleNet1-3 nrpe[22847]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:15:40 tribbleNet1-3 nrpe[22847]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:15:40 tribbleNet1-3 nrpe[22847]: Error: Could not complete SSL handshake. 1
Feb 28 14:15:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:16:11 tribbleNet1-3 nrpe[22860]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:16:11 tribbleNet1-3 nrpe[22860]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:16:11 tribbleNet1-3 nrpe[22860]: Error: Could not complete SSL handshake. 1
Feb 28 14:16:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:16:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:16:27 tribbleNet1-3 nrpe[22872]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:16:27 tribbleNet1-3 nrpe[22872]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:16:27 tribbleNet1-3 nrpe[22872]: Error: Could not complete SSL handshake. 1
Feb 28 14:16:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:16:43 tribbleNet1-3 nrpe[22876]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:16:43 tribbleNet1-3 nrpe[22876]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:16:43 tribbleNet1-3 nrpe[22876]: Error: Could not complete SSL handshake. 1
Feb 28 14:16:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:16:59 tribbleNet1-3 nrpe[22892]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:16:59 tribbleNet1-3 nrpe[22892]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:16:59 tribbleNet1-3 nrpe[22892]: Error: Could not complete SSL handshake. 1
Feb 28 14:17:01 tribbleNet1-3 CRON[22894]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Feb 28 14:17:25 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 14:17:25 ntop[1476]: last message repeated 2 times
Feb 28 14:17:25 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 14:17:25 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 14:17:25 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 14:17:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:17:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:17:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:17:30 tribbleNet1-3 nrpe[22920]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:17:30 tribbleNet1-3 nrpe[22920]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:17:30 tribbleNet1-3 nrpe[22920]: Error: Could not complete SSL handshake. 1
Feb 28 14:17:55 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 14:17:55 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 14:17:55 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 14:17:55 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 14:17:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:18:03 tribbleNet1-3 nrpe[22943]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:18:03 tribbleNet1-3 nrpe[22943]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:18:03 tribbleNet1-3 nrpe[22943]: Error: Could not complete SSL handshake. 1
Feb 28 14:18:25 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 14:18:25 ntop[1476]: last message repeated 2 times
Feb 28 14:18:25 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 14:18:25 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 14:18:25 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (15994->8232)
Feb 28 14:18:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:18:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:18:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:18:33 tribbleNet1-3 nrpe[22964]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:18:33 tribbleNet1-3 nrpe[22964]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:18:33 tribbleNet1-3 nrpe[22964]: Error: Could not complete SSL handshake. 1
Feb 28 14:18:55 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 14:18:55 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 14:18:55 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 14:18:55 ntop[1476]: last message repeated 2 times
Feb 28 14:18:55 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 14:18:55 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (13098->8232)
Feb 28 14:18:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:19:05 tribbleNet1-3 nrpe[22976]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:19:05 tribbleNet1-3 nrpe[22976]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:19:05 tribbleNet1-3 nrpe[22976]: Error: Could not complete SSL handshake. 1
Feb 28 14:19:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:19:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:19:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:20:01 snmpd[1661]: last message repeated 3 times
Feb 28 14:20:01 tribbleNet1-3 CRON[23010]: (www-data) CMD (php /usr/share/cacti/site/poller.php >/dev/null 2>/var/log/cacti/poller-error.log)
Feb 28 14:20:08 tribbleNet1-3 nrpe[23014]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:20:08 tribbleNet1-3 nrpe[23014]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:20:08 tribbleNet1-3 nrpe[23014]: Error: Could not complete SSL handshake. 1
Feb 28 14:20:26 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 14:20:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:20:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:20:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:20:40 tribbleNet1-3 nrpe[23028]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:20:40 tribbleNet1-3 nrpe[23028]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:20:40 tribbleNet1-3 nrpe[23028]: Error: Could not complete SSL handshake. 1
Feb 28 14:20:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:21:11 tribbleNet1-3 nrpe[23044]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:21:11 tribbleNet1-3 nrpe[23044]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:21:11 tribbleNet1-3 nrpe[23044]: Error: Could not complete SSL handshake. 1
Feb 28 14:21:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:21:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:21:27 tribbleNet1-3 nrpe[23055]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:21:27 tribbleNet1-3 nrpe[23055]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:21:27 tribbleNet1-3 nrpe[23055]: Error: Could not complete SSL handshake. 1
Feb 28 14:21:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:21:43 tribbleNet1-3 nrpe[23059]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:21:43 tribbleNet1-3 nrpe[23059]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:21:43 tribbleNet1-3 nrpe[23059]: Error: Could not complete SSL handshake. 1
Feb 28 14:21:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:21:59 tribbleNet1-3 nrpe[23072]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:21:59 tribbleNet1-3 nrpe[23072]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:21:59 tribbleNet1-3 nrpe[23072]: Error: Could not complete SSL handshake. 1
Feb 28 14:22:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:22:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:22:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:22:30 tribbleNet1-3 nrpe[23089]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:22:30 tribbleNet1-3 nrpe[23089]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:22:30 tribbleNet1-3 nrpe[23089]: Error: Could not complete SSL handshake. 1
Feb 28 14:22:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:23:03 tribbleNet1-3 nrpe[23117]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:23:03 tribbleNet1-3 nrpe[23117]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:23:03 tribbleNet1-3 nrpe[23117]: Error: Could not complete SSL handshake. 1
Feb 28 14:23:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:23:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:23:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:23:33 tribbleNet1-3 nrpe[23137]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:23:33 tribbleNet1-3 nrpe[23137]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:23:33 tribbleNet1-3 nrpe[23137]: Error: Could not complete SSL handshake. 1
Feb 28 14:23:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:24:05 tribbleNet1-3 nrpe[23150]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:24:05 tribbleNet1-3 nrpe[23150]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:24:05 tribbleNet1-3 nrpe[23150]: Error: Could not complete SSL handshake. 1
Feb 28 14:24:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:24:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:24:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:25:01 snmpd[1661]: last message repeated 3 times
Feb 28 14:25:01 tribbleNet1-3 CRON[23178]: (www-data) CMD (php /usr/share/cacti/site/poller.php >/dev/null 2>/var/log/cacti/poller-error.log)
Feb 28 14:25:08 tribbleNet1-3 nrpe[23182]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:25:08 tribbleNet1-3 nrpe[23182]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:25:08 tribbleNet1-3 nrpe[23182]: Error: Could not complete SSL handshake. 1
Feb 28 14:25:26 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 14:25:26 ntop[1476]: last message repeated 2 times
Feb 28 14:25:26 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 14:25:26 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 14:25:26 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (13098->8232)
Feb 28 14:25:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:25:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:25:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:25:40 tribbleNet1-3 nrpe[23194]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:25:40 tribbleNet1-3 nrpe[23194]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:25:40 tribbleNet1-3 nrpe[23194]: Error: Could not complete SSL handshake. 1
Feb 28 14:25:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:26:11 tribbleNet1-3 nrpe[23210]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:26:11 tribbleNet1-3 nrpe[23210]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:26:11 tribbleNet1-3 nrpe[23210]: Error: Could not complete SSL handshake. 1
Feb 28 14:26:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:26:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:26:27 tribbleNet1-3 nrpe[23221]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:26:27 tribbleNet1-3 nrpe[23221]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:26:27 tribbleNet1-3 nrpe[23221]: Error: Could not complete SSL handshake. 1
Feb 28 14:26:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:26:43 tribbleNet1-3 nrpe[23225]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:26:43 tribbleNet1-3 nrpe[23225]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:26:43 tribbleNet1-3 nrpe[23225]: Error: Could not complete SSL handshake. 1
Feb 28 14:26:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:26:59 tribbleNet1-3 nrpe[23240]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:26:59 tribbleNet1-3 nrpe[23240]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:26:59 tribbleNet1-3 nrpe[23240]: Error: Could not complete SSL handshake. 1
Feb 28 14:27:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:27:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:27:26 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 14:27:26 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 14:27:26 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 14:27:26 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 14:27:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:27:30 tribbleNet1-3 nrpe[23264]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:27:30 tribbleNet1-3 nrpe[23264]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:27:30 tribbleNet1-3 nrpe[23264]: Error: Could not complete SSL handshake. 1
Feb 28 14:27:57 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 14:27:57 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 14:27:57 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 14:27:57 ntop[1476]: last message repeated 2 times
Feb 28 14:27:57 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (14546->8232)
Feb 28 14:27:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:28:03 tribbleNet1-3 nrpe[23289]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:28:03 tribbleNet1-3 nrpe[23289]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:28:03 tribbleNet1-3 nrpe[23289]: Error: Could not complete SSL handshake. 1
Feb 28 14:28:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:28:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:28:27 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 14:28:27 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 14:28:27 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (17442->8232)
Feb 28 14:28:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:28:33 tribbleNet1-3 nrpe[23311]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:28:33 tribbleNet1-3 nrpe[23311]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:28:33 tribbleNet1-3 nrpe[23311]: Error: Could not complete SSL handshake. 1
Feb 28 14:28:57 tribbleNet1-3 ntop[1476]: errno 10 while sending page to web client
Feb 28 14:28:57 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 14:28:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:29:05 tribbleNet1-3 nrpe[23326]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:29:05 tribbleNet1-3 nrpe[23326]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:29:05 tribbleNet1-3 nrpe[23326]: Error: Could not complete SSL handshake. 1
Feb 28 14:29:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:29:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:29:27 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (10202->8232)
Feb 28 14:29:27 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 14:29:27 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (8754->8232)
Feb 28 14:29:27 ntop[1476]: last message repeated 2 times
Feb 28 14:29:27 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (13098->8232)
Feb 28 14:29:27 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (18890->8232)
Feb 28 14:29:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:30:01 snmpd[1661]: last message repeated 3 times
Feb 28 14:30:01 tribbleNet1-3 CRON[23357]: (www-data) CMD (php /usr/share/cacti/site/poller.php >/dev/null 2>/var/log/cacti/poller-error.log)
Feb 28 14:30:08 tribbleNet1-3 nrpe[23361]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:30:08 tribbleNet1-3 nrpe[23361]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:30:08 tribbleNet1-3 nrpe[23361]: Error: Could not complete SSL handshake. 1
Feb 28 14:30:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:30:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:30:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:30:40 tribbleNet1-3 nrpe[23376]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:30:40 tribbleNet1-3 nrpe[23376]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:30:40 tribbleNet1-3 nrpe[23376]: Error: Could not complete SSL handshake. 1
Feb 28 14:30:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:31:11 tribbleNet1-3 nrpe[23392]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:31:11 tribbleNet1-3 nrpe[23392]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:31:11 tribbleNet1-3 nrpe[23392]: Error: Could not complete SSL handshake. 1
Feb 28 14:31:27 tribbleNet1-3 nrpe[23394]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:31:27 tribbleNet1-3 nrpe[23394]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:31:27 tribbleNet1-3 nrpe[23394]: Error: Could not complete SSL handshake. 1
Feb 28 14:31:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:31:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:31:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:31:43 tribbleNet1-3 nrpe[23405]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:31:43 tribbleNet1-3 nrpe[23405]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:31:43 tribbleNet1-3 nrpe[23405]: Error: Could not complete SSL handshake. 1
Feb 28 14:31:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:31:59 tribbleNet1-3 nrpe[23416]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:31:59 tribbleNet1-3 nrpe[23416]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:31:59 tribbleNet1-3 nrpe[23416]: Error: Could not complete SSL handshake. 1
Feb 28 14:32:27 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:32:27 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:32:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:32:30 tribbleNet1-3 nrpe[23431]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:32:30 tribbleNet1-3 nrpe[23431]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:32:30 tribbleNet1-3 nrpe[23431]: Error: Could not complete SSL handshake. 1
Feb 28 14:32:38 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (65226->8232)
Feb 28 14:32:38 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (29026->8232)
Feb 28 14:32:38 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (30474->8232)
Feb 28 14:32:38 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (34818->8232)
Feb 28 14:32:38 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (39162->8232)
Feb 28 14:32:38 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (26130->8232)
Feb 28 14:32:38 tribbleNet1-3 ntop[1476]: **WARNING** packet truncated (11650->8232)
Feb 28 14:32:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:33:03 tribbleNet1-3 nrpe[23459]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:33:03 tribbleNet1-3 nrpe[23459]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:33:03 tribbleNet1-3 nrpe[23459]: Error: Could not complete SSL handshake. 1
Feb 28 14:33:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:33:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:33:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:33:33 tribbleNet1-3 nrpe[23484]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:33:33 tribbleNet1-3 nrpe[23484]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:33:33 tribbleNet1-3 nrpe[23484]: Error: Could not complete SSL handshake. 1
Feb 28 14:33:58 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:34:05 tribbleNet1-3 nrpe[23499]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:34:05 tribbleNet1-3 nrpe[23499]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:34:05 tribbleNet1-3 nrpe[23499]: Error: Could not complete SSL handshake. 1
Feb 28 14:34:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:34:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:34:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)
Feb 28 14:35:01 snmpd[1661]: last message repeated 3 times
Feb 28 14:35:01 tribbleNet1-3 CRON[23531]: (www-data) CMD (php /usr/share/cacti/site/poller.php >/dev/null 2>/var/log/cacti/poller-error.log)
Feb 28 14:35:08 tribbleNet1-3 nrpe[23535]: warning: /etc/hosts.allow, line 13: missing newline or line too long
Feb 28 14:35:08 tribbleNet1-3 nrpe[23535]: warning: /etc/hosts.allow, line 13: all the subsequent rules will be ignored
Feb 28 14:35:08 tribbleNet1-3 nrpe[23535]: Error: Could not complete SSL handshake. 1
Feb 28 14:35:26 tribbleNet1-3 postfix/smtpd[21799]: connect from localhost[127.0.0.1]
Feb 28 14:35:26 tribbleNet1-3 postfix/smtpd[21799]: disconnect from localhost[127.0.0.1]
Feb 28 14:35:28 tribbleNet1-3 snmpd[1661]: error on subcontainer 'ia_addr' insert (-1)/ Re: New NRPE error - error receiving data from daemon
This is the file that contains the default checks available through the linux server wizard. This would be the place to modify checks if you need to. What error are you currently receiving for the checks setup by the wizard?
You have to edit the two configuration files /etc/hosts.allow and /etc/hosts.deny (you can get a detailed explanation of the format with man hosts_access):
/etc/hosts.allow:
What does you /etc/hosts.allow look like?
Additionally, you are still receiving ssl errors. I will have to take a look at the ubuntu package to see if ssl was built in.
Feb 28 14:34:05 tribbleNet1-3 nrpe[23499]: Error: Could not complete SSL handshake. 1/etc/hosts.allow:
nrpe: <ip address of xi server>Additionally, you are still receiving ssl errors. I will have to take a look at the ubuntu package to see if ssl was built in.
Current hosts.allow looks like : ALL: 10.10.0.31
If the last line of a hosts access file is not a newline character (created by pressing the Enter key) you will see the errors you are experiencing.
Unfortunately that wasn't the problem.scottwilkerson wrote:If the last line of a hosts access file is not a newline character (created by pressing the Enter key) you will see the errors you are experiencing.
Well I'm still having horrible trouble with the CHECK_NRPE: Error receiving data from daemon. I'm going to try and reinstall the agent to see if that helps. Otherwise, I'm stuck.
Are you still receiving the new line error? If so, how are you editing the file? On the linux box directly, or are you editing in widows by way of filezilla etc?
I wasn't aware I was getting a newline error. I edited the hosts.allow file with Vi. And yes on the linux box directly. So there is no newline in that command.abrist wrote:Are you still receiving the new line error? If so, how are you editing the file? On the linux box directly, or are you editing in widows by way of filezilla etc?
