RE: Nagios Home Page
abrist
Red Shirt
Re: RE: Nagios Home Page
Post by abrist »
You have declared "AuthType Digest" which uses htdigest, whereas the default "AuthType Basic" uses htpasswd. Additionally, did you fix the ScriptAlias path?
devilsguest
Post by devilsguest »
Here is the issue again.............When i give "AllowOverride None" it's not asking me for a password and directly I can see the web console. But, when I change it to "AllowOverried AuthConfig" password i enter is not being accepted and kicking me back with same error which we were struggling to solve.
[auth_basic:error]AH01617: user nagiosadmin: authentication failure for "/nagios/": Password Mismatch
I don't really understand why nagios is behaving so weird or the problem is with the newer version of webserver. I am sick to work on one environment since last 2 weeks. God would be the only one who might have known answer to this situation...... :oops:
abrist
Red Shirt
Post by abrist »
I just upgraded one of my core instances to apache 2.4.4 and the old (default) vhosts file works fine.
Did you fix the ScriptAlias path?
What does your vhost config look like at this point?
devilsguest
ScriptAlias /nagios/cgi-bin "/usr/local/nagios/sbin/"
<Directory "/usr/local/nagios/sbin/">
Options ExecCGI
AllowOverride AuthConfig
Require all granted
AuthName "Nagios Web Access"
AuthType Digest
AuthUserFile /usr/local/nagios/etc/htpasswd.users
Require valid-user
</Directory>
ScriptAlias /nagios "/usr/local/nagios/share/"
<Directory "/usr/local/nagios/share/">
Options None
Require all granted
AuthType Digest
Require valid-user
</Directory>
devilsguest
where do i find this file called
"/nagios/"
what is it actually.....what type of file is it on core 3.4.4
sreinhardt
-fno-stack-protector
Post by sreinhardt »
/nagios/ is actually referencing the virtual host directory, and tells apache what to retieve from the filesystem to get the proper files for that site. The line ScriptAlias /nagios "/usr/local/nagios/share/" States that referencing /nagios/ in your web browser will point apache to files in /usr/local/nagios/share/. The files contained inside of that folder are largely CGI scripts.
