Help with NRDS?
Re: Help with NRDS?
jbennett wrote:YES! I had changed this initially when looking at the config file, but that would have been overwritten when I finally installed it correctly instead of how I was doing it. I've changed this now. Do I need to restart the NRDP server somehow?
No, it should work if you send the command again
Lets run this one more time
/usr/local/nrdp/clients/nrds/nrds.pl -H testlane2
Then wait just a moment and check unconfigured objects.
Being we have 6 commands and only 5 are being submitted we may be able to troubleshoot the problem one by seeing which check isn't making it to unconfigured objects.
jbennett
Re: Help with NRDS?
Post by jbennett »
I just came back after 4 days and I still don't have any unconfigured objects. :(
Re: Help with NRDS?
When you ran the following command:
did you see an output, similar to the one below?
Sent x checks to http://x.x.x.x/nrdp/
jbennett
Re: Help with NRDS?
Post by jbennett »
That was the last thing I did on this box before I left. Here's the output from that command:
testlane2:/usr/local/nrdp/clients # /usr/local/nrdp/clients/nrds/nrds.pl -H testlane2
ERROR: STDIN must be either 3 or 4 fields long, I found 2
Sent 5 checks to http://xxx.xxx.xxx.xxx/nrdp/
Re: Help with NRDS?
Run the following command and show us the output of it:
ll /usr/local/nagiosxi/var/corelog.newobjects
When you open the "corelog.newobjects" in a text editor, do you see the "testlane2" in there?
jbennett
Re: Help with NRDS?
Post by jbennett »
I take it this should be run on the Nagios server?
I will send you the results. testlane2 is NOT listed in the file.
Re: Help with NRDS?
Post the output whenever you have time - just wanted to see the permissions.
jbennett
Re: Help with NRDS?
Post by jbennett »
Here are the permissions. I have already PMd the output.
-rwxrwxr-x 1 nagios nagios 378 Mar 28 14:36 corelog.newobjects
Re: Help with NRDS?
These permissions look fine. Let's try this - select the NRDS task in the Task Scheduler, click on "Run", and check if there is anything in the Unconfigured Options.
jbennett
Re: Help with NRDS?
Post by jbennett »
lmiltchev wrote:These permissions look fine. Let's try this - select the NRDS task in the Task Scheduler, click on "Run", and check if there is anything in the Unconfigured Options.
Pardon my ignorance, but where can I find the Task Scheduler?
