Can't add MiBs to Nagios XI
sreinhardt
- -fno-stack-protector
Re: Can't add MiBs to Nagios XI
So you are still failing on the ./A-subcomponents portion correct? What is the latest error message you have gotten and is this after exporting INSTALL_PATH. I should also note that install path is expected to be /tmp/nagiosxi and you can verify this via "echo $INSTALL_PATH"
