Check Windows Processes
abrist
Red Shirt
Re: Check Windows Processes
Post by abrist »
ofadl wrote:i ran the ping 10.200.50.76 and didint get a reply
Well, you have a networking problem. Is the nagios server on the same subnet as your workstation?
ofadl
Post by ofadl »
what do u mean by that?
abrist
Red Shirt
Post by abrist »
ofadl wrote:0.0.0.0 10.200.40.1 0.0.0.0 UG 100 0 0 eth0
10.200.40.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
Given your subnet mask, you most likely cannot talk to the 10.200.50.x subnet. You will need to contact a sysadmin to get a new route added to the router at 10.200.40.1 to route to the 10.200.50.x subnet. This is not something we can do for you. You will have to resolve the networking issues with your admins.
ofadl
Post by ofadl »
so i just spoke with my boss about the networking issue, and he confirmed its not a problem with the network. We tried :
telnet 10.200.50.176 5666
and it worked fine
Post by slansing »
It looks like "10.200.50.76" is the IP we've been trying.. is 10.200.50.176 the actual IP now?
ofadl
Post by ofadl »
oh wow, i am so sorry, that was my mistake.. the ip all along was 10.200.50.176 i apoligze. But even when i try to run a check_nrpe on that server, im getting a socket timeout after 10 seconds for check_nrpe
sreinhardt
-fno-stack-protector
Post by sreinhardt »
We can try a couple things:
check_nrpe -H 10.200.50.176 -p 5666 -t 30
Also try an nmap just to be sure from nagios that there are no issues.
nmap -p 5666 10.200.50.176
Your result should look something like:
Starting Nmap 5.51 ( http://nmap.org ) at 2013-07-02 13:13 CDT
Nmap scan report for localhost (127.0.0.1)
Host is up (0.000045s latency).
PORT     STATE SERVICE
5666/tcp open  nrpe
ofadl
Post by ofadl »
ok i ran the first command, and that increased the timeout to 30 seconds, then ran:
and got :
Starting Nmap 5.21 ( http://nmap.org ) at 2013-07-02 14:43 EDT
Nmap scan report for vnadat121.and.comtexnews.net (10.200.50.176)
Host is up (0.00091s latency).
PORT STATE SERVICE
5666/tcp open nrpe
Nmap done: 1 IP address (1 host up) scanned in 0.11 seconds
sreinhardt
OK so you have definitely confirmed the connection is open and responding. What was returned from the first command, hopefully the remove nrpe servers version?
ofadl
Post by ofadl »
yes the connection is open and responding. The first command:
returns as follows:
CHECK_NRPE: Socket timeout after 30 seconds.
