i cant make non-official plugins to work
Re: i cant make non-official plugins to work
yes /usr/local/libexec/check_snmp_printer: function: not found
On CLI if i change the script #!/bin/sh to #!/bin/bash it gives me no errors. but when i leave it at /sh i comes with the function: not found error.
This could be an issue with the interpreter. If it is working on your system with #!/bin/bash I would change it to that.
I changed it. and now it is back to (Return code of 127 is out of bounds - plugin may be missing) again....
(i also just changed the default shell from csh to bash, same result...return code of 127...)
Does the altered check now work from the cli and is just reporting the 127 error through nagios?
Yes just the 127 error in nagios
What are the permissions on this plugin now? Can you run the following:
ll -la /usr/local/nagios/libexec/pluginnameRe: i cant make non-official plugins to work
-rwxr-xr-x 1 root wheel 32647 Sep 26 09:58 /usr/local/libexec/check_snmp_printer
This is what you meant, right?
Can you run the check as the user "nagios" ?
Yes i can run the command as nagios.
Altough i do not know which user runs the commands from the website, could it be another user?
The commands should be run as the user 'nagios'. Do you only have issues with this one plugin?
