abrist wrote:All the required packages installed successfully. Do you have a log from the configure and make?
cgi error
Re: cgi error
Re: cgi error
Run:
Post these two log files in code wraps or attachment.
./configure &> /tmp/configure.log
make all &> /tmp/make.logFormer Nagios employee
Re: cgi error
I have attached the log files .
make.log- (2.62 KiB) Downloaded 249 times
configure.log- (9.68 KiB) Downloaded 224 times
Re: cgi error
You are missing a few dependencies that are required to build all the cgis:
Then:
If you have continued issues, post the logs once again.
yum install gd-devel png-devel jpg-devel -yCode: Select all
make clean
Re: cgi error
after running the mentioned command i am still not able to see statusmap.cgj file.
attached the files.
attached the files.
make.log- (9.51 KiB) Downloaded 237 times
configure.log- (9.68 KiB) Downloaded 241 times
sreinhardt
- -fno-stack-protector
Re: cgi error
Can you run the following command and send us the results please.
rpm -qa | grep 'gd-devel\|png-devel\|jpeg\|jpg'Nagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
Re: cgi error
please find the below output
[root@CNPUDAS011 ~]# rpm -qa | grep 'gd-devel\|png-devel\|jpeg\|jpg'
openjpeg-libs-1.3-9.el6_3.x86_64
libjpeg-turbo-devel-1.2.1-1.el6.x86_64
libjpeg-turbo-1.2.1-1.el6.x86_64
libpng-devel-1.2.49-1.el6_2.x86_64
Re: cgi error
You are still missing gd-devel:
yum install gd-devel -yFormer Nagios employee
Re: cgi error
Hi
I tried all the option that you have mentioned . But while installing th GB i am getting below error.
[root@CNPUDAS011 httpd]# yum install gd-devel png-devel jpg-devel install gd-devel -y
Loaded plugins: product-id, refresh-packagekit, security, subscription-manager
This system is receiving updates from Red Hat Subscription Management.
rhel-6-server-cf-tools-1-rpms | 2.8 kB 00:00
rhel-6-server-rhev-agent-rpms | 3.1 kB 00:00
rhel-6-server-rpms | 3.7 kB 00:00
Setting up Install Process
No package gd-devel available.
No package png-devel available.
No package jpg-devel available.
No package install available.
Error: Nothing to do
I have installed the Nagios on Linux .
Red Hat Enterprise Linux Server release 6.4 (Santiago)
Kernel \r on an \m
[root@CNPUDAS011 httpd]# uname -a
Linux CNPUDAS011 2.6.32-358.el6.x86_64 #1 SMP Tue Jan 29 11:47:41 EST 2013 x86_64 x86_64 x86_64 GNU/Linux
Kernel \r on an \m
