upgrading from 3.4.1 to 4.0.1
vivithemage
Re: upgrading from 3.4.1 to 4.0.1
Post by vivithemage »
If that is the case, is there a way around it? A replacement? What was it's purpose to begin with?
Thanks for all your guys' help so far, super useful :).
abrist
Red Shirt
Post by abrist »
ndoutils is used to copy the status information from the logs into a mysql db. We are planning to fix up ndo for core 4 (it is one of the things the devs are working on atm), but we do not have a release schedule. I suspect, at the latest, that ndo will support core 4 by the time we release the next revision of XI (early 2014 tba).
vivithemage
ahhh, I think we need it for the amount of services we check....I might have to roll back to the latest 3.x instead of 4.01 then. Is there an alternative?
unless you think it cane keep up without an SQL? We have 1600~ service checks.
does the latest 3.x take perl scripts and run them as one process, as opposed to many? We noticed 3.4.1 does many, and that's bogging our system down.
abrist
Red Shirt
Post by abrist »
SQL DBs will not make your server check faster. It is strictly for the preservation of historical data.
vivithemage
Is there an easy way to remove that configuration to see if i can get it to run?
abrist
Red Shirt
Post by abrist »
Comment out the line:
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
in:
 /usr/local/nagios/etc/nagios.cfg
And restart nagios:
service nagios restart
vivithemage
looks like that did the trick :).
Thanks a lot! See if I run into anything else.
Keeping this thread open for a bit in case you have more.
vivithemage
looks like I am seeing a lot of these now:
[1383857191] SERVICE NOTIFICATION: nagiosadmin;infprd63;Apache IDM;CRITICAL;notify-service-by-email;CHECK_NRPE: Error - Could not complete SSL handshake.
[1383857192] SERVICE NOTIFICATION: nagiosadmin;p014_node02;client1139;CRITICAL;notify-service-by-email;(No output on stdout) stderr:
[1383857196] SERVICE NOTIFICATION: nagiosadmin;p014_node01;client1131;CRITICAL;notify-service-by-email;(No output on stdout) stderr:
Post by slansing »
What plugins package did you end up compiling? You are talking about the stderr output correct?
