plugins to monitor wifi Access points and Controllers
Re: plugins to monitor wifi Access points and Controllers
Post by slansing »
One glaring issue, your group is named "nagiocmd" was this intentional? By default it should be, and is expected to be, "nagcmd"...unless you intentionally switched it when you originally configured nagios.
http://assets.nagios.com/downloads/nagi ... Source.pdf
To change it back to default, use:
groupmod --new-name nagcmd nagiocmd
kimjaggi
Post by kimjaggi »
Hi, yes it was by intentional. I have reinstalled Nagios because it was taking too long to resolve this issue.
Thanks to all of you for the replies. I will still like to keep this thread open because I havent tested the original wifi monitoring thing.
abrist
Red Shirt
Post by abrist »
Fair enough. Let us know if you have further issues.
We'll keep this open for you. Keep us updated.
kimjaggi
Post by kimjaggi »
Ok- so check_aruba.pl worked after doing the changes in OIDs. SO this thread is okay to close.
If anyone looking for the script - Please feel free to use the attached script. I have made the required changes so now it works with DELL W-650 wifi (Aruba OS). I used it for monitoring Access points (up and down status only). One have to explore if they want more things to be monitored.
You might get error
/usr/bin/perl^M: bad interpreter: No such file or directory
while running the script, to resolve this I Removed ^M control chars by using following command
perl -i -pe 'y|\r||d' script.pl
Check_aruba_dell.pl
Script to monitor access points of DELL wifi controller
(29.68 KiB) Downloaded 460 times
