Authentication problem
eloyd
Cool Title Here
Re: Authentication problem
Post by eloyd »
ifconfig show the private IP, i enter the private IP or public?
You should use whatever IP address that you will be using to connect to the web server. Look at http://httpd.apache.org/docs/2.2/mod/co ... irtualhost and specifically this part:
With the NameVirtualHost directive you specify the IP address on which the server will receive requests for the name-based virtual hosts. This will usually be the address to which your name-based virtual host names resolve. In cases where a firewall or other proxy receives the requests and forwards them on a different IP address to the server, you must specify the IP address of the physical interface on the machine which will be servicing the requests. If you have multiple name-based hosts on multiple addresses, repeat the directive for each address.
I think you may be misconfigured as a virtual host server. Beyond that, I'd recommend starting over with a new AWS EC2 instance and a new install of Nagios.
hellb0y77
Post by hellb0y77 »
Nothing....same problem, i will consider to re-create the istance
Thank you all for your time and patience
Stefano
Let us know when you have the new server and we'll see if you run into the same issues.
