Hi Eric,
Oddly, the output of the plugin ended up in the performance data part of it. It's not entirely odd ... the way that things are currently handled (pre-nrdp/pre-APIs) is that the performance data portion of nagios was hijacked for data purposes. Since I'm still having to use that setup while testing the new nrdp/API setup, this kind of thing happens.
Also, if I use the API to only print out this service, there is no problem. It only happens when I ask for all services.
I also found out that if I change the line in cgi/jsonutils.c from:
{ L"\n", L"\\n" },Code: Select all
{ L"\n", L" "},All that being said here is the first portion of what is in the perf_data (it's crazy long and will need to be sanitized if I give you any more than this part ... but it seems to be failing in this first portion, so I hope this much is helpful):
pbspl1.nas.nasa.gov: Mon Aug 11 14:59:35 2014\\n Server reports 1391 jobs total (T:0 Q:982 H:31 W:0 R:378 E:0 B:0)\\n\\n Host CPUs Tasks Jobs Info\\n ----------- ----- ----- ---- ----------------------------\\n 40 hosts 800 0 -- ivy\\n 3 hosts 60 0 -- ivy bigmem\\n 160 hosts 2980 0 -- ivy down\\n 1798 hosts 35960 34166 -- ivy in-use\\n 2618 hosts 2080 0 -- ivy offline\\n 30 hosts 600 30 -- ivy q=alphatst in-use\\n 72 hosts 1440 0 -- ivy q=devel\\n 50 hosts 940 0 -- ivy q=devel down\\n 501 hosts 10020 10005 -- ivy q=devel in-use\\n 9 hosts 180 0 -- ivy q=devel offline\\n 3 hosts 60 0 -- ivy q=devel {offline down}\\n 18 hosts 360 0 -- ivy q=diags\\n 5 hosts 20 0 -- ivy q=diags offline\\n 3 hosts 60 0 -- ivy q=orbit_spl\\n r417i0n1 0 0 0 ivy q=orbit_spl offline\\n r417i0n6 0 0 0 ivy q=orbit_spl offline\\n r401i7n3 20 0 0 ivy q=resize_test offline\\n 33 hosts 660 660 -- ivy q=smd_ops in-use\\n 10 hosts 200 0 -- ivy q=smd_ops offline\\n r469i5n0 20 0 0 ivy q=smd_ops {offline down}\\n 37 hosts 740 0 -- ivy {offline down}\\n r405i6n17 20 20 1 ivy {offline in-use}\\n r447i5n15 20 20 1 ivy {offline in-use}\\n 4 hosts 80 0 -- ivy_exa bigmem\\n ldan7 16 0 0 ldan\\n ldan8 16 0 0 ldan\\n ldan4 16 16 1 ldan in-use\\n ldan5 16 16 1 ldan in-use\\n 3 hosts 48 0 -- ldan offline\\n ldan6 16 16 1 ldan {offline in-use}\\n 4 hosts 16 0 -- san down\\n 520 hosts 8320 7906 -- san in-use\\n 996 hosts 496 0 -- san offline\\n 36 hosts 576 0 -- san q=datasciences\\n 36 hosts 576 0 -- san q=devel\\n 26 hosts 400 0 -- san q=devel down\\n 225 hosts 3600 3600 -- san q=devel in-use\\n 10 hosts 160 0 -- san q=devel offline\\n r303i1n14 16 0 0 san q=diags\\n 5 hosts 0 0 -- san q=diags offline\\n r303i2n6 16 0 0 san q=resize_test offline\\n 9 hosts 144 0 -- san q=smd_ops offline\\n r303i5n0 16 0 0 san {offline down}\\n r305i3n15 16 0 0 san {offline down}\\n 53 hosts 1272 0 -- wes\\n 13 hosts 312 0 -- wes bigmem\\n r138i3n15 24 0 0 wes bigmem down\\n r152i3n15 0 0 0 wes bigmem down\\n 5 hosts 120 34 -- wes bigmem in-use\\n r151i3n15 24 0 0 wes bigmem q=diags\\n 5 hosts 0 0 -- wes down\\n 1420 hosts 34080 14296 -- wes in-use\\n 1866 hosts 2304 0 -- wes offline\\n 157 hosts 3768 0 -- wes q=devel\\n r130i2n1 0 0 0 wes q=devel down\\n r138i1n0 0 0 0 wes q=devel down\\n 282 hosts 6768 3294 -- wes q=devel in-use\\n 11 hosts 168 0 -- wes q=devel offline\\n r129i1n10 24 0 0 wes q=diags\\n 3 hosts 24 0 -- wes q=diags down\\n 12 hosts 0 0 -- wes q=diags offline\\n 4 hosts 96 0 -- wes q=resize_test\\n r144i3n0 24 0 0 wes q=smd_ops offline\\n r222i3n15 0 0 0 wes q=smd_ops offline\\n r203i3n3 24 0 0 wes {offline down}\\n 61 hosts 1464 0 -- wes_gpu m2090\\n r219i0n2 0 0 0 wes_gpu m2090 down\\n r219i0n7 0 0 0 wes_gpu m2090 down\\n r219i3n12 24 0 0 wes_gpu m2090 offline\\n\\nGroup Share% Use% Share Exempt Use Avail Borrowed Ratio Waiting\\n------- ------ ---- ----- ------ ----- ----- -------- ----- -------\\nOverall 100 0 86390 2 124 86266 0 0.00 2932\\n ARMD 27 30 23722 0 25944 0 2222 1.09 67288\\n HEOMD 26 19 22859 0 17032 5827 0 0.75 37156\\n SMD 43 38 37093 601 33468 3625 0 0.90 129344\\n NEX 1 0 862 0 772 90 0 0.90 3016\\n NAS 2 0 1725 0 80 1645 0 0.05 8256\\n\\n -janice
