This support forum board is for support questions relating to
Nagios XI, our flagship commercial network monitoring solution.
Post
by rkennedy »
That error is generally related to not being able to find the command.
Just to verify, when you say added lines, there are quite a few steps for this. Did you add this one to your NSC.ini?
Add the following to the [External Scripts] section in NSC.ini:
get_rdp_info=cscript.exe //T:30 //NoLogo scripts\get_rdp_info.vbs
Additionally, where did you place the get_rdp_info.vbs script?
dlukinski
Post
by dlukinski »
rkennedy wrote:That error is generally related to not being able to find the command.
Added my NSC.ini file / script was place under \scripts in NSC folder
Post
by rkennedy »
In your NSC.ini I noticed the get_rdp_info is specified under the external scripts, however it is missing a \
currently it's -
get_rdp_info=cscript.exe //T:30 //NoLogo scriptsget_rdp_info.vbs
it should be -
Let us know if that fixes it for you.
dlukinski
Post
by dlukinski »
rkennedy wrote:In your NSC.ini I noticed the get_rdp_info is specified under the external scripts, however it is missing a \
currently it's -
it should be -
Thank you (I also forgot to uncomment check external scripts DLL).
- works now.
hsmith
- Agent Smith
Post
by hsmith »
If there's nothing else we can do for you
@dlukinski, I'll go ahead and close the thread due to age. Are you all set?
Former Nagios Employee.
me.
dlukinski
Post
by dlukinski »
hsmith wrote:If there's nothing else we can do for you
Yes please close the ticket and thank you once again!
Post
by rkennedy »
I will now close this out. If you ever need assistance in the future, feel free to open a new thread.
