How to query complex regex pattern in nagios log server
jolson
Attack Rabbit
Re: How to query complex regex pattern in nagios log server
Post by jolson »
If you change your HTTP bind address, does that make a difference?
vi /etc/httpd/conf/httpd.conf
Change "Listen 80" to "Listen <yourIP>:80"
Restart httpd:
service httpd restart
If that does not work, feel free to revert the settings.
My next hunch would be elasticsearch's bind port:
vi /usr/local/nagioslogserver/elasticsearch/config/elasticsearch.yml
Change "# network.bind_host: 192.168.0.1" to "network.bind_host: <yourIP>" - please note that you must remove the comment preceding the line.
You will have to restart elasticsearch:
service elasticsearch restart
If that does not work, please feel free to revert the settings.
Let me know if this works for you!
Jesse
Twits Blog
jolson
Attack Rabbit
Post by jolson »
After speaking with a developer about this particular thread, I have learned that Nagios Log Server will always pull 127.0.0.1 unless you specify a cluster hostname in Admin > Global Settings. That should resolve your issue. Please keep in mind that there is currently a bug regarding Action URLs that will be fixed in the next release. Thanks!
Twits Blog
Jklre
Post by Jklre »
jolson wrote:After speaking with a developer about this particular thread, I have learned that Nagios Log Server will always pull 127.0.0.1 unless you specify a cluster hostname in Admin > Global Settings. That should resolve your issue. Please keep in mind that there is currently a bug regarding Action URLs that will be fixed in the next release. Thanks!
Yes changing the cluster host setting did the trick. Thank you.
jolson
Attack Rabbit
Post by jolson »
No problem - may I close this thread out, or do you have further questions?
Twits Blog
