XI installation and failover design
gormank
Re: XI installation and failover design
Post by gormank »
My understanding from the license agreement is that monitoring from 2 sites as described would require 2 separate licenses, correct? A single license allows for one actively monitoring, one passive failover and one backup if I understand things...
jolson
Attack Rabbit
Post by jolson »
gormank wrote:My understanding from the license agreement is that monitoring from 2 sites as described would require 2 separate licenses, correct? A single license allows for one actively monitoring, one passive failover and one backup if I understand things...
You are correct - https://support.nagios.com/wiki/index.p ... #Licensing
Production Install - The main monitoring install for a given license key. This is the install that system administrators use on their production servers and infrastructure to monitor their environment and receive notifications when systems are not working properly.
Test/Lab Environment - The second install is for use in a test environment. This ensures that when upgrades are necessary, or major configuration changes are implemented, there are not adverse effects to the main monitoring system. The test install allows teams to “preview” their changes without jeopardizing the main system.
Backup Install - The final installation use case for a given license key is for use as a backup/failover of the Nagios XI Production install. This allows for a high-availability system to be setup, or can be used as a complete backup of the production install
Twits Blog
gormank
Post by gormank »
Sorry, I misread jolsen's post above. His example disables/enables monitoring and notifications. I thought it was only notifications. Monitoring at one site at a time should be ok.
ssax
Dreams In Code
Post by ssax »
Yes, active/passive monitoring need to be disabled on the failover system which essential makes notifications useless anyways because nothing would notify from that server until they were re-enabled.
mp4783
Post by mp4783 »
The suggestion of simply modifying the nagios.cfg file is both elegant and easy to implement. Thank you so much for the suggestion, it will make our failover design much easier and will keep us in compliance with our licenses.
Thank you!
@gormank are we clear to lock the thread?
gormank
Post by gormank »
The answer seems to be "we don't have a high availability solution and simply offer various options for customers to possibly choose."
I gave up on this thread long ago so feel free to close it.
