Log Server Mointoring
gdolidze
Re: Log Server Mointoring
Post by gdolidze »
Now that the linux side is done how am I to do this on the the windows side.
jolson
Attack Rabbit
Post by jolson »
On the Windows side, I've tested this using check_log3.exe instead of check_log3.pl. Check_log3.exe can be downloaded here: http://sourceforge.net/projects/pma-oss ... s-plugins/
You will need to have NSClient running on your Windows Servers. You can download NSClient here: http://www.nsclient.org/download/
Once downloaded, you'll need to adjust nsclient.ini - I used the following configuration:
[/settings/default]
allowed hosts = 192.168.1.1/24
password = somepass
[/modules]
NSClientServer = 1
CheckSystem = 1
CheckDisk = 1
NRPEServer = 1
[/settings/NRPE/server]
use ssl = 1
payload length = 1024
allow nasty characters = false
allowed ciphers = ADH
ssl = 1
allow arguments = 1
insecure = 1
check_log3 = scripts\check_log3.exe "-p somestring" "-l C:\testlog" "-c 1" --no-timeout
Then restart NSclient on the windows box with an administrative cmd prompt:
net stop nscp
net start nscp
Once it's restarted, you can call the Windows machine in much the same way you'd call a linux box:
[root@localhost ~]# /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -c check_log3
OK: Found 0 lines (limit=1/1): No matches found.|'lines'=0
Twits Blog
gdolidze
Post by gdolidze »
So I am doing this on a different server now everything works but I deleted a service but now cant apply.
Write host configurations ...
Host configuration files successfully written!
Write service configurations ...
Configuration file: ils.cjh.org.cfg successfully written!
Service configuration files successfully written!
Configuration file: hostgroups.cfg successfully written!
Configuration file: servicegroups.cfg successfully written!
Configuration file: hosttemplates.cfg successfully written!
Configuration file: servicetemplates.cfg successfully written!
Configuration file: timeperiods.cfg successfully written!
Configuration file: commands.cfg successfully written!
Configuration file: contacts.cfg successfully written!
Configuration file: contactgroups.cfg successfully written!
Configuration file: contacttemplates.cfg successfully written!
Configuration file: servicedependencies.cfg successfully written!
Configuration file: hostdependencies.cfg successfully written!
Configuration file: serviceescalations.cfg successfully written!
Configuration file: hostescalations.cfg successfully written!
Configuration file: serviceextinfo.cfg successfully written!
Configuration file: hostextinfo.cfg successfully written!
Error: Invalid max_attempts, check_interval, retry_interval, or notification_interval value for service 'Secure Log' on host 'ils.cjh.org'
Error: Could not register service (config file '/usr/local/nagios/etc/services/Messages log.cfg', starting on line 16)
jolson
Attack Rabbit
Post by jolson »
Navigate to Configuration -> Core Config Manager -> Services and select 'ils.cjh.org' from the dropdown.
Once selected, look for the service 'Secure Log' and either delete it or change the max_attempts/check_interval/retry_interval/notification_interval values appropriately.
Twits Blog
gdolidze
Post by gdolidze »
The thing is I already deleted it so nothing comes up with that name.
jolson
Attack Rabbit
Post by jolson »
Please access 'Configure -> Core Config Manager -> Write Config Files' and click the following buttons one at a time:
Delete
Write
Verify
Restart
Let us know if you get any useful output. If not, please log into the CLI and try the following:
su - nagios
./reconfigure_nagios.sh
Best,
Jesse
Twits Blog
gdolidze
Post by gdolidze »
RESTART FAILED. CONFIG ERROR:
Error: Could not find any host matching 'cfjh.net' (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 34)
Error: Could not expand members specified in hostgroup (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 34)
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.login--2015-05-15 11:59:22--  http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
Length: unspecified [text/html]
Saving to: “nagiosql.login”
    [ <=>                                   ] 10,831      --.-K/s   in 0.01s
2015-05-15 11:59:22 (857 KB/s) - “nagiosql.login” saved [10831]
LOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
SETUID ROOT OK
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.login--2015-05-15 11:59:23--  http://localhost/nagiosxi/includes/components/ccm/
    [ <=>                                   ] 10,831      --.-K/s   in 0.02s
2015-05-15 11:59:23 (578 KB/s) - “nagiosql.login” saved [10831]
LOGIN SUCCESSFUL!
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
Saving to: “nagiosql.export.monitoring”
    [    <=>                                ] 18,257      5.90K/s   in 3.0s
2015-05-15 11:59:27 (5.90 KB/s) - “nagiosql.export.monitoring” saved [18257]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
   Read main config file okay...
Warning: Duplicate definition found for service 'SQL Server' on host 'cfjh08.cfjh.net' (config file '/usr/local/nagios/etc/services/cfjh08.cfjh.net.cfg', starting on line 217)
Warning: Duplicate definition found for service 'Messages Pending Routing' on host 'cfjh16.cfjh.net' (config file '/usr/local/nagios/etc/services/cfjh16.cfjh.net.cfg', starting on line 145)
Warning: Duplicate definition found for service 'Domain Expiration' on host 'cjh.org' (config file '/usr/local/nagios/etc/services/ajhs.org.cfg', starting on line 80)
Warning: Duplicate definition found for service 'Domain Expiration' on host 'cfjh.net' (config file '/usr/local/nagios/etc/services/cfjh.net.cfg', starting on line 16)
Warning: Duplicate definition found for service 'Domain Expiration' on host 'jewishcommons.org' (config file '/usr/local/nagios/etc/services/ajhs.org.cfg', starting on line 80)
Warning: Duplicate definition found for service 'Domain Expiration' on host 'jewishwarheroes.org' (config file '/usr/local/nagios/etc/services/ajhs.org.cfg', starting on line 80)
     directives and data defintions.  If you are upgrading from a previous
     may have been removed or modified in this version.  Make sure to read
RET: 1
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /usr/local/nagiosxi/scripts
tar: Removing leading `/' from member names
LATEST NOM SNAPSHOT: /usr/local/nagiosxi/nom/checkpoints/nagioscore/1431634871.tar.gz
/ /usr/local/nagiosxi/scripts
RESTORING NOM SNAPSHOT : /usr/local/nagiosxi/nom/checkpoints/nagioscore/1431634871.tar.gz
tar: usr/local/nagios/etc/hosts: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/hosts: Cannot change mode to rwsrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/pnp/pages: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/pnp/pages: Cannot change mode to rwxrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/pnp/check_commands: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/pnp/check_commands: Cannot change mode to rwxrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/pnp: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/pnp: Cannot change mode to rwxrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/import: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/import: Cannot change mode to rwsrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/services: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/services: Cannot change mode to rwsrwsr-x: Operation not permitted
tar: usr/local/nagios/etc/static: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc/static: Cannot change mode to rwsrwsr-x: Operation not permitted
tar: usr/local/nagios/etc: Cannot utime: Operation not permitted
tar: usr/local/nagios/etc: Cannot change mode to rwsrwsr-x: Operation not permitted
tar: Exiting with failure status due to previous errors
SETUID ROOT OK
RESETTING PERMS
# Hostgroup configuration file
# Created by: Nagios Core Config Manager 2.3.3
# Date:       2015-05-15 12:02:24
# Version:    Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
define hostgroup {
        hostgroup_name                          domains-expire-status
        alias                                   Domain Expiration Status
        members                                 cfjh.net,cjh.org
define hostgroup {
        hostgroup_name                          linux-servers
        alias                                   Linux Servers
        members                                 ajhs.org,contributors.cjh.org,digital.cjh.org,ils.cjh.org,ilstest.cjh.org,keemu.cjh.org,search.cjh.org
define hostgroup {
        hostgroup_name                          nagios-server
        alias                                   Nagios Monitoring Server
        members                                 localhost
define hostgroup {
        hostgroup_name                          windows-servers
        alias                                   Windows
        members                                 cfjh.net,cfjh00.cfjh.net,cfjh08.cfjh.net,cfjh10.cfjh.net,cfjh12.cfjh.net,cfjh16.cfjh.net,cfjh50.cfjh.net,cfjh51.cfjh.net,hadassah00.cfjh.net,jewishcommons.org,jewishwarheroes.org,vm-web11.cjh.org,web09.cjh.org,web11.cjh.org,yivoserver01.cfjh.net,yivoserver02.cfjh.net
# Timeperiod configuration file
# END OF FILE
jolson
Attack Rabbit
Post by jolson »
There might be some permission problems. Let's try and fix those. Please log into your CLI as root and run the following:
bash reset_config_perms.sh
After you have completed the above, try re-running our previous test:
su - nagios
Twits Blog
gdolidze
Post by gdolidze »
Still same issue.
[root@nagiosxi-prod scripts]# bash reset_config_perms.sh
RESETTING PERMS
[root@nagiosxi-prod scripts]# su - nagios
[nagios@nagiosxi-prod ~]$ cd /usr/local/nagiosxi/scripts
[nagios@nagiosxi-prod scripts]$ ./reconfigure_nagios.sh
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://loca            lhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'subm            it=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O             nagiosql.login--2015-05-15 13:21:44--  http://localhost/nagiosxi/includes/compon            ents/ccm/
2015-05-15 13:21:45 (847 KB/s) - “nagiosql.login” saved [10831]
LOGIN SUCCESSFUL!
Array
SETUID ROOT OK
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://loca            lhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'subm            it=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O             nagiosql.login--2015-05-15 13:21:45--  http://localhost/nagiosxi/includes/compon            ents/ccm/
    [ <=>                                   ] 10,831      --.-K/s   in 0.005s
2015-05-15 13:21:46 (1.94 MB/s) - “nagiosql.login” saved [10831]
LOGIN SUCCESSFUL!
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes            /components/ccm/ --no-check-certificate --post-data 'cmd=apply&type=writeConfig'             -O nagiosql.export.monitoring
--2015-05-15 13:21:46--  http://localhost/nagiosxi/includes/components/ccm/
    [     <=>                               ] 18,257      4.59K/s   in 3.9s
2015-05-15 13:21:50 (4.59 KB/s) - “nagiosql.export.monitoring” saved [18257]
OUTPUT:
Nagios Core 4.0.8
Copyright (c) 2009-present Nagios Core Development Team and Community Contributo            rs
License: GPL
Warning: Duplicate definition found for service 'SQL Server' on host 'cfjh08.cfj            h.net' (config file '/usr/local/nagios/etc/services/cfjh08.cfjh.net.cfg', starti            ng on line 217)
Warning: Duplicate definition found for service 'Messages Pending Routing' on ho            st 'cfjh16.cfjh.net' (config file '/usr/local/nagios/etc/services/cfjh16.cfjh.ne            t.cfg', starting on line 145)
Warning: Duplicate definition found for service 'Domain Expiration' on host 'cjh            .org' (config file '/usr/local/nagios/etc/services/ajhs.org.cfg', starting on li            ne 80)
Warning: Duplicate definition found for service 'Domain Expiration' on host 'cfj            h.net' (config file '/usr/local/nagios/etc/services/cfjh.net.cfg', starting on l            ine 16)
Warning: Duplicate definition found for service 'Domain Expiration' on host 'jew            ishcommons.org' (config file '/usr/local/nagios/etc/services/ajhs.org.cfg', star            ting on line 80)
Warning: Duplicate definition found for service 'Domain Expiration' on host 'jew            ishwarheroes.org' (config file '/usr/local/nagios/etc/services/ajhs.org.cfg', st            arting on line 80)
Error: Invalid max_attempts, check_interval, retry_interval, or notification_int            erval value for service 'Secure Log' on host 'ils.cjh.org'
Error: Could not register service (config file '/usr/local/nagios/etc/services/M            essages log.cfg', starting on line 16)
RET: 1
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /usr/local/nagiosxi/script            s
LATEST NOM SNAPSHOT: /usr/local/nagiosxi/nom/checkpoints/nagioscore/1431634871.t            ar.gz
RESTORING NOM SNAPSHOT : /usr/local/nagiosxi/nom/checkpoints/nagioscore/14316348            71.tar.gz
tar: usr/local/nagios/etc/pnp/check_commands: Cannot utime: Operation not permit            ted
tar: usr/local/nagios/etc/pnp/check_commands: Cannot change mode to rwxrwsr-x: O            peration not permitted
tar: usr/local/nagios/etc/pnp: Cannot change mode to rwxrwsr-x: Operation not pe            rmitted
tar: usr/local/nagios/etc/services: Cannot change mode to rwsrwsr-x: Operation n            ot permitted
tar: usr/local/nagios/etc: Cannot change mode to rwsrwsr-x: Operation not permit            ted
SETUID ROOT OK
RESETTING PERMS
ssax
Dreams In Code
Post by ssax »
Try running this as root and post the full output:
