Nagvis URL not found
Re: Nagvis URL not found
Got it working. Is there a way to consolidate nagvis and nagiosxi logins so that we don't have to maintain both?
They are separate logins and there isn't a way to sync them.
Is there a way to disable to login per user for nagvis?
lmiltchev wrote:Make sure you have all these lines commented out in the "/etc/httpd/conf.d/nagvis.conf" file:Then, add the following lines on the bottom of the file (under the "</Directory>" line):Code: Select all
# AuthName "NagVis Access" # AuthType Basic # AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users # Require valid-userOpen the "/usr/local/nagvis/etc/nagvis.ini.php" file in a text editor, and comment out this line:Code: Select all
RewriteEngine on RewriteLock var/log/rewrite.lck RewriteLog /dev/null RewriteLogLevel 0 RewriteRule /nagvis/ - [E=REMOTE_USER:nagiosadmin]so that it will look like this:Code: Select all
logonenvvar="PHP_AUTH_USER"Restart apache:Code: Select all
; logonenvvar="PHP_AUTH_USER"Let me know if this worked.Code: Select all
service httpd restart
Taken from here: https://support.nagios.com/forum/viewto ... 509#p62509
I get the error:
Unable to authenticate user. The environment variable REMOTE_USER is not set or empty.
Have you restarted apache?
Try clearing browser's cache and loggin in again (or try a different browser). Did this work? If not, can you post the "/etc/httpd/conf.d/nagvis.conf" and the "/usr/local/nagvis/etc/nagvis.ini.php" files?
service httpd restartBe sure to check out our Knowledgebase for helpful articles and solutions!
I used a different browser and did restart apache.
# NagVis Apache2 sample configuration file
Alias /nagvis "/usr/local/nagvis/share"
<Directory "/usr/local/nagvis/share">
Options FollowSymLinks
AllowOverride None
Order allow,deny
Allow from all
# To enable Nagios basic auth on NagVis use the following options
# Just uncomment it. Maybe you need to adjust the path to the
# Auth user file.
# If you use the NagVis internal auth mechanism based on the web
# for you won't need this.
# AuthType Basic
# AuthUserFile /usr/local/nagiosxi/etc/htpasswd.nagvis
# With installed and enabled mod_rewrite there are several redirections
# available to fix deprecated and/or wrong urls. None of those rules is
# mandatory to get NagVis working.
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /nagvis
# Use mod_rewrite for old url redirection even if there are php files which
# redirect the queries itselfs. In some cases the mod_rewrite redirect
# is better than the php redirect.
RewriteCond %{REQUEST_URI} ^/nagvis(/index\.php|/|)(\?.*|)$
RewriteRule ^(index\.php|)(\?.*|)$ /nagvis/frontend/nagvis-js/$1$2 [R=301,L]
RewriteCond %{REQUEST_URI} ^/nagvis/config\.php.*$
RewriteRule ^config\.php(.*) /nagvis/frontend/wui/$1 [R=301,L]
# Redirect old regular map links
RewriteCond %{REQUEST_URI} ^/nagvis/frontend/nagvis-js
RewriteCond %{QUERY_STRING} map=(.*)
RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/index.php?mod=Map&act=view&show=%1 [R=301,L]
# Redirect old wui map links
RewriteCond %{REQUEST_URI} ^/nagvis/frontend/wui
RewriteRule ^(.*)$ /nagvis/frontend/wui/index.php?mod=Map&act=edit&show=%1 [R=301,L]
# Redirect old rotation calls
RewriteCond %{QUERY_STRING} !mod
RewriteCond %{QUERY_STRING} rotation=(.*)
RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/index.php?mod=Rotation&act=view&show=%1 [R=301,L]
</IfModule>
</Directory>
RewriteEngine on
RewriteLogLevel 0
; <?php return 1; ?>
; the line above is to prevent
; viewing this file from web.
; DON'T REMOVE IT!
; Default NagVis Configuration File
; At delivery everything here is commented out. The default values are set in the NagVis code.
; You can make your changes here, they'll overwrite the default settings.
; !!! The sections/variables with a leading ";" won't be recognised by NagVis (commented out) !!!
; General options which affect the whole NagVis installation
[global]
; Enable/Disable logging of security related user actions in Nagvis. For
; example user logins and logouts are logged in var/nagvis-audit.log
;audit_log="1"
; Defines the authentication module to use. By default NagVis uses the built-in
; SQLite authentication module. On delivery there is no other authentication
; module available. It is possible to add own authentication modules for
; supporting other authorisation mechanisms. For details take a look at the
; documentation.
;authmodule="CoreAuthModSQLite"
; Defines the authorisation module to use. By default NagVis uses the built-in
; SQLite authorisation module. On delivery there is no other authorisation
; module available. It is possible to add own authorisation modules for
; documentation.
;authorisationmodule="CoreAuthorisationModSQLite"
; Dateformat of the time/dates shown in nagvis (For valid format see PHP docs)
;dateformat="Y-m-d H:i:s"
; Defines which translations of NagVis are available to the users
;language_available="de_DE,en_US,es_ES,fr_FR,pt_BR"
; Language detection steps to use. Available:
; - User: The user selection
; - Session: Language saved in the session (Usually set after first setting an
; explicit language)
; - Browser: Detection by user agent information from the browser
; - Config: Use configured default language (See below)
;language_detection="user,session,browser,config"
; Select language (Available by default: en_US, de_DE, fr_FR, pt_BR)
;language="en_US"
; Defines the logon module to use. There are three logon modules to be used by
; default. It is possible to add own logon modules for serving other dialogs or
; ways of logging in. For details take a look at the documentation.
; The delivered modules are:
; LogonMixed: The mixed logon module uses the LogonEnv module as default and
; the LogonDialog module as fallback when LogonEnv returns no username. This
; should fit the requirements of most environments.
; LogonDialog: This is an HTML logon dialog for requesting authentication
; information from the user.
; LogonEnv: It is possible to realise a fully "trusted" authentication
; mechanism like all previous NagVis versions used it before. This way the user
; is not really authenticated with NagVis. NagVis trusts the provided username
; implicitly. NagVis uses the configured environment variable to identify the
; user. You can add several authentication mechanisms to your webserver,
; starting from the basic authentication used by Nagios (.htaccess) to single
; sign-on environments.
; Simply set logonmodule to "LogonEnv", put the environment variable to use as
; username to the option logonenvvar and tell the authentication module to
; create users in the database when provided users does not exist. The option
; logonenvcreaterole tells the module to assign the new user to a specific role
; set to empty string to disable that behaviour.
logonmodule="LogonEnv"
;logonenvcreateuser="1"
;logonenvcreaterole="Guests"
; Default rotation time of pages in rotations
;refreshtime=60
; Some user information is stored in sessions which are identified by session
; cookies placed on the users computer. The options below set the properties
; of the session cookie.
; Domain to set the cookie for. By default NagVis tries to auto-detect this
; options value by using the webserver's environment variables.
;sesscookiedomain="auto-detect"
; Absolute web path to set the cookie for. This defaults to configured
; paths/htmlbase option
;sesscookiepath="/nagvis"
; Lifetime of the NagVis session cookie in seconds. The default value is set to
; 24 hours. The NagVis session cookie contents will be renewed on every page
; visit. If a session is idle for more time than configured here it will become
; invalid.
;sesscookieduration="86400"
; Start page to redirect the user to when first visiting NagVis without
; special parameters.
;startmodule="Overview"
;startaction="view"
; The startshow parameter is only used by some views at the moment. It is used
; by the Map and the AutoMap modules.
;startshow=""
; Path definitions
[paths]
; absolute physical NagVis path
;base="/usr/local/nagvis/"
; absolute html NagVis path
;htmlbase="/nagvis"
; absolute html NagVis cgi path
htmlcgi="/nagiosxi/includes/components/xicore"
; Default values which get inherited to the maps and its objects
[defaults]
; default backend (id of the default backend)
backend="ndomy_1"
backend="ndomy_1"
; background color of maps
;backgroundcolor="#ffffff"
; Enable/Disable the context menu on map objects. With the context menu you are
; able to bind commands or links to your map objects
;contextmenu=1
; Choose the default context template
;contexttemplate="default"
; Enable/Disable changing background color on state changes (Configured color is
; shown when summary state is PENDING, OK or UP)
;eventbackground=0
; Enable/Disable highlighting of the state changing object by adding a flashing
; border
;eventhighlight=1
; The duration of the event highlight in milliseconds (10 seconds by default)
;eventhighlightduration=10000
; The interval of the event highlight in milliseconds (0.5 seconds by default)
;eventhighlightinterval=500
; Enable/Disable the eventlog in the new javascript frontend. The eventlog keeps
; track of important actions and information
;eventlog=0
; Loglevel of the eventlog (available: debug, info, warning, critical)
;eventloglevel="info"
; Height of the eventlog when visible in px
;eventlogheight="75"
; Hide/Show the eventlog on page load
;eventloghidden="1"
; Enable/Disable scrolling to the icon which changed the state when the icon is
; out of the visible scope
;eventscroll=1
; Enable/Disable sound signals on state changes
;eventsound=1
; enable/disable header menu
;headermenu="1"
; header template
;headertemplate="default"
; Enable/Diable the fading effect of the submenus in the header menu
;headerfade=1
; enable/disable hover menu
;hovermenu=1
; hover template
;hovertemplate="default"
; hover menu open delay (seconds)
;hoverdelay=0
; show children in hover menus
;hoverchildsshow=1
; limit shown child objects to n
;hoverchildslimit="10"
; order method of children (desc: descending, asc: ascending)
;hoverchildsorder="asc"
; sort method of children (s: state, a: alphabetical)
;hoverchildssort="s"
; default icons
;icons="std_medium"
; recognize only hard states (not soft)
;onlyhardstates=0
; recognize service states in host/hostgroup objects
;recognizeservices=1
; show map in lists (dropdowns, index page, ...)
;showinlists=1
; show map in multisite snapin
;showinmultisite=1
; Name of the custom stylesheet to use on the maps (The file needs to be located
; in the share/nagvis/styles directory)
;stylesheet=""
; target for the icon links
;urltarget="_self"
; URL template for host object links
hosturl="[htmlcgi]/status.php?host=[host_name]"
; URL template for hostgroup object links
hostgroupurl="[htmlcgi]/status.php?show=services&hostgroup=[hostgroup_name]"
; URL template for service object links
serviceurl="[htmlcgi]/status.php?show=servicedetail&host=[host_name]&service=[service_description]&dest=auto"
; URL template for servicegroup object links
servicegroupurl="[htmlcgi]/status.php?show=services&servicegroup=[servicegroup_name]"
; URL template for nested map links
;mapurl="[htmlbase]/index.php?mod=Map&act=view&show=[map_name]"
; Options to configure the Overview page of NagVis
[index]
; Color of the overview background
;backgroundcolor=#ffffff
; Set number of map cells per row
;cellsperrow=4
;headermenu="1"
; header template
; Enable/Disable automap listing
;showautomaps=1
; Enable/Disable map listing
;showmaps=1
; Enable/Disable geomap listing
; Note: It is disabled here since it is unfinished yet and not for production
; use in current 1.5 code.
;showgeomap=0
; Enable/Disable rotation listing
;showrotations=1
; Enable/Disable map thumbnails
;showmapthumbs=0
; Options for the Automap
[automap]
; Default URL parameters for links to the automap
;defaultparams="&childLayers=2"
; Default root host (NagVis uses this if it can't detect it via NDO)
;defaultroot=""
; Path to the graphviz binaries (dot,neato,...); Only needed if not in ENV PATH
;graphvizpath="/usr/bin/"
; Show the automap in the lists (Map index and dropdown menu in header)
;showinlists=1
; Options for the WUI
[wui]
; Users which are allowed to change the NagVis configuration (comma separated list)
;allowedforconfig=EVERYONE
; auto update frequency
;autoupdatefreq=25
; enable/disable header menu in the WUI
;headermenu="1"
; header template to use in the WUI
; map lock time (minutes)
;maplocktime=5
; Options for the new Javascript worker
[worker]
; The interval in seconds in which the worker will check for objects which need
; to be updated
;interval=10
; The maximum number of parameters used in ajax http requests
; Some intrusion detection/prevention systems have a problem with
; too many parameters in the url. Give 0 for no limit.
;requestmaxparams=0
; The maximum length of http request urls during ajax http requests
; queries being too long
;requestmaxlength=1900
; The retention time of the states in the frontend in seconds. The state
; information will be refreshed after this time
;updateobjectstates=30
; Backend definitions
; Example definition of a livestatus backend.
; In this case the backend_id is live_1
; The path /usr/local/nagios/var/rw has to exist
[backend_live_1]
backendtype="mklivestatus"
; The status host can be used to prevent annoying timeouts when a backend is not
; reachable. This is only useful in multi backend setups.
; It works as follows: The assumption is that there is a "local" backend which
; monitors the host of the "remote" backend. When the remote backend host is
; reported as UP the backend is queried as normal.
; When the remote backend host is reported as "DOWN" or "UNREACHABLE" NagVis won't
; try to connect to the backend anymore until the backend host gets available again.
; The statushost needs to be given in the following format:
; "<backend_id>:<hostname>" -> e.g. "live_2:nagios"
;statushost=""
;socket="unix:/usr/local/nagios/var/rw/live"
; Example definition for a MySQL backend
; in this example the ID of the Backend is "ndomy_1" you can define another ID.
[backend_ndomy_1]
; type of backend - MUST be set
backendtype="ndomy"
;statushost=""
; hostname for NDO-db
;dbhost="localhost"
; portname for NDO-db
;dbport=3306
; database name for NDO-db
;dbname="nagios"
; username for NDO-db
dbuser="ndoutils"
; password for NDO-db
dbpass="n@gweb"
; prefix for tables in NDO-db
;dbprefix="nagios_"
; instance name for tables in NDO-db
dbinstancename="localhost"
; maximum delay of the NDO Database in seconds
;maxtimewithoutupdate=180
; path to the cgi-bin of this backend
;htmlcgi="/nagios/cgi-bin"
; Example definition of a Merlin backend
; in this example the ID of the Backend is "merlinmy_1" you can define another ID.
[backend_merlinmy_1]
backendtype="merlinmy"
; hostname for Merlin db
;dbhost="localhost"
; portname for Merlin db
;dbport=3306
; database name for Merlin db
;dbname="merlin"
; username for Merlin db
;dbuser="merlin"
; password for Merlin db
;dbpass="merlin"
; maximum delay of the Merlin Database in seconds
; Rotation pool definitions
; in this example the browser switches between the maps demo and demo2 every 15
; seconds, the rotation is enabled by url: index.php?rotation=demo
[rotation_demo]
; These steps are rotated. The "Demo2:" is a label which is being displayed in
; the index pages rotation list.
; You may also add external URLs as steps. Simply enclose the url using []
; instead of the map name. It is also possible to add automaps to rotations,
; add an @ sign before the automap name to add an automap to the rotation.
maps="demo,Demo2:demo2"
; rotation interval (seconds)
interval=15
; Below you find some advanced stuff
; Configure different state related settings
[states]
; State coverage/weight: This defines the state handling behaviour. For example
; a critical state will cover a warning state and an acknowledged critical
; state will not cover a warning state.
; These options are being used when calculating the summary state of the map
; objects. The default values should fit most needs.
;unreachable=9
;unreachable_ack=5
;unreachable_downtime=5
;down=8
;down_ack=5
;down_downtime=5
;critical=7
;critical_ack=5
;critical_downtime=5
;warning=6
;warning_ack=4
;warning_downtime=4
;unknown=3
;unknown_ack=2
;unknown_downtime=2
;error=3
;error_ack=2
;error_downtime=2
;up=1
;ok=1
;pending=0
; Colors of the different states. The colors are used in lines and hover menus
; and for example in the frontend highlight and background event handler
;unreachable_bgcolor=#F1811B
;unreachable_color=#F1811B
;unreachable_ack_bgcolor=
;unreachable_downtime_bgcolor=
;down_bgcolor=#FF0000
;down_color=#FF0000
;down_ack_bgcolor=
;down_downtime_bgcolor=
;critical_bgcolor=#FF0000
;critical_color=#FF0000
;critical_ack_bgcolor=
;critical_downtime_bgcolor=
;warning_bgcolor=#FFFF00
;warning_color=#FFFF00
;warning_ack_bgcolor=
;warning_downtime_bgcolor=
;unknown_bgcolor=#FFCC66
;unknown_color=#FFCC66
;unknown_ack_bgcolor=
;unknown_downtime_bgcolor=
;error_bgcolor=#0000FF
;error_color=#0000FF
;up_bgcolor=#00FF00
;up_color=#00FF00
;ok_bgcolor=#00FF00
;ok_color=#00FF00
;pending_bgcolor=#C0C0C0
;pending_color=#C0C0C0
; Sound of the different states to be used by the sound eventhandler in the
; frontend. The sounds are only being fired when changing to some
; worse state.
;unreachable_sound=std_unreachable.mp3
;down_sound=std_down.mp3
;critical_sound=std_critical.mp3
;warning_sound=std_warning.mp3
;unknown_sound=
;error_sound=
;up_sound=
;ok_sound=
;pending_sound=
; EOF
AllowOverride None
Order allow,deny
Allow from all
# Auth user file.
# AuthType Basic
RewriteEngine On
RewriteBase /nagvis
</IfModule>
</Directory>
RewriteEngine on
RewriteLogLevel 0
; DON'T REMOVE IT!
[global]
;audit_log="1"
; documentation.
; documentation.
;language="en_US"
;refreshtime=60
; invalid.
;startaction="view"
;startshow=""
; Path definitions
[paths]
;htmlbase="/nagvis"
[defaults]
backend="ndomy_1"
backend="ndomy_1"
;contextmenu=1
;eventbackground=0
; border
;eventhighlight=1
;eventlog=0
;eventloghidden="1"
;eventscroll=1
;eventsound=1
;headermenu="1"
; header template
;headerfade=1
;hovermenu=1
; hover template
;hoverdelay=0
;hoverchildsshow=1
; default icons
;icons="std_medium"
;onlyhardstates=0
;showinlists=1
;showinmultisite=1
;stylesheet=""
;urltarget="_self"
[index]
;cellsperrow=4
;headermenu="1"
; header template
;showautomaps=1
;showmaps=1
;showgeomap=0
;showrotations=1
;showmapthumbs=0
[automap]
;defaultroot=""
;showinlists=1
[wui]
;autoupdatefreq=25
;headermenu="1"
;maplocktime=5
[worker]
; to be updated
;interval=10
;requestmaxparams=0
[backend_live_1]
;statushost=""
[backend_ndomy_1]
backendtype="ndomy"
;statushost=""
;dbhost="localhost"
;dbport=3306
;dbname="nagios"
dbuser="ndoutils"
dbpass="n@gweb"
;dbprefix="nagios_"
;dbhost="localhost"
;dbport=3306
;dbname="merlin"
;dbuser="merlin"
;dbpass="merlin"
[rotation_demo]
interval=15
[states]
;unreachable=9
;unreachable_ack=5
;down=8
;down_ack=5
;down_downtime=5
;critical=7
;critical_ack=5
;warning=6
;warning_ack=4
;warning_downtime=4
;unknown=3
;unknown_ack=2
;unknown_downtime=2
;error=3
;error_ack=2
;error_downtime=2
;up=1
;ok=1
;pending=0
;down_color=#FF0000
;down_ack_bgcolor=
;up_bgcolor=#00FF00
;up_color=#00FF00
;ok_bgcolor=#00FF00
;ok_color=#00FF00
; worse state.
;unknown_sound=
;error_sound=
;up_sound=
;ok_sound=
;pending_sound=
; EOF
I had the same error as you and I had to add this line in the /etc/httpd/conf.d/nagvis.conf file above the other section that was added to the bottom if the file.
Add this line
setenv REMOTE_USER nagiosadmin
to the file like so
Then restart apache
Add this line
to the file like so
RewriteEngine on
RewriteLock /var/log/rewrite.lck
RewriteLogLevel 0
This logs me in directly as the nagiosadmin account into nagiosxi and nagvis with no authentication. I need folks to be able to login to nagiosxi using their own credentials.
tgriep wrote:I had the same error as you and I had to add this line in the /etc/httpd/conf.d/nagvis.conf file above the other section that was added to the bottom if the file.
Add this line
to the file like soThen restart apacheCode: Select all
setenv REMOTE_USER nagiosadmin RewriteEngine on RewriteLock /var/log/rewrite.lck RewriteLog /dev/null RewriteLogLevel 0 RewriteRule /nagvis/ - [E=REMOTE_USER:nagiosadmin]Code: Select all
Ok, the issue is with where you are putting it:
Please move this line:
Inside the </Directory> code so it looks like this:
Then:
setenv REMOTE_USER nagiosadminCode: Select all
</Directory>
RewriteEngine on
RewriteLogLevel 0
