Monitor Disk Usage of Windows Mount Points...
hsmith
Agent Smith
Re: Monitor Disk Usage of Windows Mount Points...
Post by hsmith »
jasonlehman wrote:
hsmith wrote:The reason that your command is failing is because...
       command_name                             check_mp
       command_line                             $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ -a $ARG2$
Inside of here $USER1$ is pointing at /usr/local/nagios/libexec since it is defined in resource.cfg as pointing at that.
You need to either move check_nrpe or change the command_line part of the command.
Make sense?
Make's perfect sense. I changed the command_line to point to the correct path; which is for me /usr/lib64/nagios/plugins/
I'm not sure why mine is different.
I now need to understand how to put in the correct path to the mount point in the check_command.
Using what was suggested... check_mp!CheckDriveSize!E:\SQL\Databases!!!!!!
I now get this result from Nagios...
Filter processing failed: Error: Failed to get size for: 3: The system cannot find the path specified.
Do I really need 6 exclamation points after my path? I'm not sure why there are so many.
I wouldn't touch the exclamation points. Instead, what I would try to do is move/copy your check_nrpe over to /usr/local/nagios/libexec and put $USER1$ back in place instead of the file path. We could be running into some weird issue with having a path there instead of $USER1$.
Try this and let me know, thanks!
Former Nagios Employee.
me.
jasonlehman
Post by jasonlehman »
Make sense?
Ok, so I copied my check_nrpe to /usr/local/nagios/libexec/
So it's now in two locations
[root@nagios objects]# find / -name check_nrpe
/usr/lib64/nagios/plugins/check_nrpe
/usr/local/nagios/libexec/check_nrpe
Modified the command back to use $USER1$/check_nrpe
# 'check_mp' command the community helped me make to check Windows Mount Points via check_nrpe
I then restarted the Nagios service.
Unfortunately, I still get the message...
BTW here is the service
#windows Mount Point for SQL Databases on host1
        host_name                       host1
        service_description             SQL DB Disk
        check_command                   check_mp!CheckDriveSize!E:\SQL\Databases!!!!!!
        register                        1
hsmith
Agent Smith
Post by hsmith »
Hmm... let's put that $ARG2$ in quotes. '$ARG2'
me.
jasonlehman
hsmith wrote:Hmm... let's put that $ARG2$ in quotes. '$ARG2'
That worked, now I get the result of...
OK All 1 drive(s) are ok
Thank you
What does it me by all drives are ok? Will this alert me if the drive starts to get full, like the check_nt!USEDDISKSPACE! will alert at warning & critical values?
If so, is there a way to set the warning & critical values?
hsmith
Agent Smith
Post by hsmith »
Thank you
./check_nrpe -H x.x.x.x-c CheckDriveSize -a Drive=D: MinCritFree=20% MinWarnFree=30%
Is the command I used for this. MinWarnFree is the minimum amount free before it warns you, MinCritFree is the amount before it goes critical. You can modify your service check to include these.
me.
jasonlehman
Would I just add MinCritFree=20% MinWarnFree=30% to the service is setup?
I tried a few different ways, but dont get any different results.
I have...
        host_name                       host1
        check_command                   check_mp!CheckDriveSize!E:\SQL\Databases!!!!!!-a MinCritFree=10% MinWarnFree=15%
        register                        1
hsmith
Agent Smith
Post by hsmith »
jasonlehman wrote:Would I just add MinCritFree=20% MinWarnFree=30% to the service is setup?
I have...
        host_name                       host1
        register                        1
Close. Add it after the Databases portion. Like so:
        host_name                       host1
        check_command                   check_mp!CheckDriveSize!E:\SQL\Databases MinCritFree=10% MinWarnFree=15%!!!!!!
        register                        1
And try.
me.
jasonlehman
I'm back to the error...
When I put it in the exclamation points...
        host_name                       host1
        register                        1
hsmith
Agent Smith
Post by hsmith »
jasonlehman wrote:I'm back to the error...
        host_name                       host1
        register                        1
There needs to be a Drive= there, I may have screwed that one up. :(
        host_name                       host1
        check_command                   check_mp!CheckDriveSize!Drive=E:\SQL\Databases MinCritFree=10% MinWarnFree=15%!!!!!!
        register                        1
me.
jasonlehman
No worries.
Unfortunately, that didn't work either.
Getting...
Here is what I have
        host_name                       host1
        register                        1
