Some alerts not firing
jolson
Attack Rabbit
Re: Some alerts not firing
Post by jolson »
Good stuff! I'll standby for your response.
Twits Blog
Jklre
Post by Jklre »
jolson wrote:Good stuff! I'll standby for your response.
Unfortunately it looks like this has not resolved the issue.
Audit logs
2015-10-13T07:20:16.678-07:00	ALERT	Alert Name 106929 CANADA: StdAssignmentDeliveryWF Error -   - Priority 3/2 returned OK: 0 matching e...
View: Table / JSON / Raw
Field	Action	Value	Search
 _id	  	AVBhkrenVjtz_tyMH_-k
 _index	  	nagioslogserver_log
 _type	  	ALERT
 created 	  	1444746016678
 message	  	Alert Name 106929 CANADA: StdAssignmentDeliveryWF Error -   - Priority 3/2 returned OK: 0 matching entries found |logs=0;0;0
 source	  	Nagios Log Server
 type	  	ALERT
2015-10-13T07:04:26.630-07:00	ALERT	Alert Name 106929 CANADA: StdAssignmentDeliveryWF Error -   - Priority 3/2 returned OK: 0 matching e...
 _id	  	AVBhhDiHVjtz_tyMH_Qd
 _type	  	ALERT
 created 	  	1444745066630
 type	  	ALERT
2015-10-13T06:48:41.753-07:00	ALERT	Alert Name 106929 CANADA: StdAssignmentDeliveryWF Error -   - Priority 3/2 returned OK: 0 matching e...
 _id	  	AVBhdc2aVjtz_tyMH-nx
 _type	  	ALERT
 created 	  	1444744121753
 type	  	ALERT
Dashboard
Alert
2015-10-13T07:04:59.396-07:00	172.26.20.140	syslog	<11>pjbc16n1lxv jboss_jbc16: node1: [ID 23854 Oct 13, 2015 7:04:59 AM com.mitchell.services.core.errorlog.server.SyslogWriter write#012SEVERE:
@timestamp 	  	2015-10-13T14:04:59.396Z
jolson
Attack Rabbit
Post by jolson »
Do you have product support? I'd like to perform a remote session with you and get to the bottom of this, but you'd need to be a paying customer. I ask because this post is in the general forum.
Twits Blog
Jklre
Post by Jklre »
Audit logs
 _type	  	ALERT
 type	  	ALERT
 _type	  	ALERT
 type	  	ALERT
 _type	  	ALERT
 type	  	ALERT
Dashboard
Alert
Looking deeper into this. This is occurring on a different cluster than our main one. It has less alerts configured (948 instead of 2000)
Running the command
[root@pcanls01lxv ~]# ps -ef | egrep "jobs|poller" | grep -v grep | wc -l
12
10
12
15
as you can see the jobs are at 12 + not sure whats causing this. I'm going to bounce the cluster and see if it gets any better.
Jklre
Post by Jklre »
After the bounce:
2
6
4
Jklre
Post by Jklre »
jolson wrote:Do you have product support? I'd like to perform a remote session with you and get to the bottom of this, but you'd need to be a paying customer. I ask because this post is in the general forum.
yes we do, but for some reason my account does not have access to that forum.
jolson
Attack Rabbit
Post by jolson »
I'll look into that - would you please send an email to [email protected] and reference this thread? I'll pick up your ticket and we can take an in-depth look at this with a developer if necessary.
Jesse
Twits Blog
Jklre
Post by Jklre »
Jesse
I went ahead and opened it up a ticket with you guys.
Thank you
jolson
Attack Rabbit
Post by jolson »
I'll go ahead and lock this thread - when we come to a resolution I'll be sure to add that here.
Twits Blog
