Nagios XI 5 Open Beta - Download Available
jomann
Development Lead
Re: Nagios XI 5 Open Beta
Post by jomann »
WillemDH wrote:
- Updated all reports to now use asynchronous loading of report information -JO
- Updated all reports to have a new layout -JO
- Added numbers of saved reports and scheduled reports to left hand menu section -JO
I really hope this means I can start using reports, as currently I have to run a report three times in order to be able to export to pdf AND running a report chokes my XI server..
This will be hard to test on my QA though, as it doesn't have that many hosts.
If you have automatic loading of reports turned off in your performance settings you should be able to use the new reports to create a pdf without having to run the report three times. Simply select the values you want and instead of clicking the "Run" button select Download > PDF.
eloyd wrote:I can see this is going to become a very confusing thread soon. Would it be possible to have a new invite-only forum group created for the Beta so topic threads can be kept together?
It does seem like it's going to be pretty confusing. A new forum might be helpful for discussion however there is no need for invites anymore since this is going to be open and the Beta download link will be in the main post.
Just to clarify, this is not a "Post issues here and we will support them" thread, this is a "Post issues here and we will add them to the dev workflow" thread. The follow-up from us will come later.
BanditBBS
Re: Nagios XI 5 Open Beta - Download Available
Post by BanditBBS »
My update just stopped without completing, here is the end:
Installing 'wizards/snmp-trap.zip'
TMPNAME: libvu
Archive:  /tmp/nagiosxi/subcomponents/xiwizards/wizards/snmp-trap.zip
snmp-trap/:  mismatching "local" filename (snmpwalk/),
         continuing with "central" filename version
   creating: snmp-trap/
file #2:  bad zipfile offset (local header sig):  40
snmp-trap/config.xml:  mismatching "local" filename (snmpwalk/sanity.sh),
  inflating: snmp-trap/config.xml
file #4:  bad zipfile offset (local header sig):  433
file #5:  bad zipfile offset (local header sig):  479
file #6:  bad zipfile offset (local header sig):  6179
file #7:  bad zipfile offset (local header sig):  6227
file #8:  bad zipfile offset (local header sig):  6633
   creating: snmp-trap/templates/
  inflating: snmp-trap/templates/snmptrap.cfg
snmp-trap
WIZARD NAME: snmp-trap
CMD=grep register_configwizard /usr/local/nagiosxi/tmp/libvu/snmp-trap/snmp-trap.inc.php | wc -l
grep: /usr/local/nagiosxi/tmp/libvu/snmp-trap/snmp-trap.inc.php: No such file or directory
0
OUT=0
CMD: rm -rf /usr/local/nagiosxi/tmp/libvu
Zip file is not a config wizard.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Scott is on the case right now, expect updates.
Update: Jake should be posting the fix shortly.
jomann
Development Lead
Post by jomann »
BanditBBS wrote:My update just stopped without completing, here is the end:
TMPNAME: libvu
snmp-trap
0
OUT=0
Just tested a newly built tarball. You should be able to re-download now and perform the upgrade. There is an issue on the file share that sometimes corrupts zip files which was the likely culprit.
BanditBBS
Post by BanditBBS »
Woot, install finished, going through a tour now :)
jolson
Attack Rabbit
Post by jolson »
Happy to hear it! :)
Twits Blog
WillemDH
Post by WillemDH »
UPGRADE COMPLETED!
Nice job on the gui guys. Does this mean no more iframes? It seems my dashboards are a bit messed up, but I forgive you for that. Had the same issue last major update. I'm guessing it's almost impossible with such major gui changes to create the exact same layout for dashboards..
Nagios XI 5.8.1
https://outsideit.net
jomann
Development Lead
Post by jomann »
WillemDH wrote:==================
UPGRADE COMPLETED!
There are still iframes, the theme is just held together tighter. The dashboards moving slightly is most likely caused by the new tables. The new tables are a bit more padded than the other ones and we were trying to keep them as similar as possible but yup - like you said - it's hard to keep it exact with this sort of change.
eloyd
Cool Title Here
Post by eloyd »
Oh God, please no more iframes...
Posting while at a stop light. So bandit, you beat me to the upgrade.
