errors in config - CHECK_PGACTIVITY plugin
Re: errors in config - CHECK_PGACTIVITY plugin
Should work now, for whatever reason PDFs were disabled for this section of the forum.
Thanks PDF will now download
All of the screenshots are in the same file
- check_pgactivity1.pdf
- (423.01 KiB) Downloaded 201 times
- Box293
- Too Basu
Great, lets try this:
In the left pane under System click Configuration
Select Commands
Click Continue
In the top right type in check_pgactivity
Click Update
Can you send a screenshot of that
Select Commands
Click Continue
Click Update
See attached file
- check_pgactivity2.pdf
- (177.68 KiB) Downloaded 220 times
- Box293
- Too Basu
Everything looks correct.
Can you please post your nagios.cfg file
see attached
nagios.cfg.txt- (46.8 KiB) Downloaded 279 times
- Box293
- Too Basu
Lets try putting the whole argument in single quotes in the service:
If you still have problems, lets reboot the entire server.
check_command check_pgactivity!'-s backends -w 80% -c 95%'As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Thanks for trying but still the same output in Nagios
Can you check the permissions on the plugin and post the results?
