ssl handshake error
avandemore
Re: ssl handshake error
I linked to a document earlier in this thread: https://support.nagios.com/forum/viewto ... 00#p203107
Please use those instructions to install NRPE 3.0.1. You will needs to place the extracted files on a file systems which does not have the noexec option active.
Previous Nagios employee
avandemore wrote:I linked to a document earlier in this thread: https://support.nagios.com/forum/viewto ... 00#p203107
so thanks
but i use from that doc and type these commands but problem not solved
cd nrpe-3.0
./configure
make all
make install
make install-config
add this line to /etc/services
nrpe 5666/tcp # NRPE
make install-init
service xinetd restart
netstat -at | egrep "nrpe|5666"
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
tcp 0 0 *:nrpe *:* LISTEN
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
getnameinfo failed
Reason: Please use code tags for output.
Please show us the exact commands you typed along with what was returned on the Nagios portion.
As for the netstat problem, please run this netstat -np | grep 5666 to stop it from trying to resolve.
rkennedy wrote:Please show us the exact commands you typed along with what was returned on the Nagios portion.
i have attached all commands with output
BR
Commands.txt- (15.48 KiB) Downloaded 394 times
avandemore
/usr/local/nagios/libexec/check_nrpe is installed by nagios-plugins, so that is the information in the document you need to be concerned about.
check_nrpe will not work correctly until ldd returns correct information. Example:
What does ldd /usr/local/nagios/libexec/check_nrpe return for you now?
[root@avandemore-centos7 mail]# ldd /usr/local/nagios/libexec/check_nrpe
linux-vdso.so.1 => (0x00007fffbe199000)
libssl.so.10 => /lib64/libssl.so.10 (0x00007fe0492e9000)
libcrypto.so.10 => /lib64/libcrypto.so.10 (0x00007fe048f01000)
libnsl.so.1 => /lib64/libnsl.so.1 (0x00007fe048ce7000)
libc.so.6 => /lib64/libc.so.6 (0x00007fe048925000)
libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007fe0486d9000)
libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007fe0483f3000)
libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007fe0481ef000)
libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007fe047fbd000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007fe047db8000)
libz.so.1 => /lib64/libz.so.1 (0x00007fe047ba2000)
/lib64/ld-linux-x86-64.so.2 (0x00007fe049561000)
libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007fe047993000)
libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007fe04778e000)
libresolv.so.2 => /lib64/libresolv.so.2 (0x00007fe047574000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fe047358000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x00007fe047132000)
libpcre.so.1 => /lib64/libpcre.so.1 (0x00007fe046ed1000)
liblzma.so.5 => /lib64/liblzma.so.5 (0x00007fe046cac000)Previous Nagios employee
this is output of command:avandemore wrote:/usr/local/nagios/libexec/check_nrpe is installed by nagios-plugins, so that is the information in the document you need to be concerned about.
check_nrpe will not work correctly until ldd returns correct information. Example:What does ldd /usr/local/nagios/libexec/check_nrpe return for you now?Code: Select all
[root@avandemore-centos7 mail]# ldd /usr/local/nagios/libexec/check_nrpe linux-vdso.so.1 => (0x00007fffbe199000) libssl.so.10 => /lib64/libssl.so.10 (0x00007fe0492e9000) libcrypto.so.10 => /lib64/libcrypto.so.10 (0x00007fe048f01000) libnsl.so.1 => /lib64/libnsl.so.1 (0x00007fe048ce7000) libc.so.6 => /lib64/libc.so.6 (0x00007fe048925000) libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007fe0486d9000) libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007fe0483f3000) libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007fe0481ef000) libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007fe047fbd000) libdl.so.2 => /lib64/libdl.so.2 (0x00007fe047db8000) libz.so.1 => /lib64/libz.so.1 (0x00007fe047ba2000) /lib64/ld-linux-x86-64.so.2 (0x00007fe049561000) libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007fe047993000) libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007fe04778e000) libresolv.so.2 => /lib64/libresolv.so.2 (0x00007fe047574000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fe047358000) libselinux.so.1 => /lib64/libselinux.so.1 (0x00007fe047132000) libpcre.so.1 => /lib64/libpcre.so.1 (0x00007fe046ed1000) liblzma.so.5 => /lib64/liblzma.so.5 (0x00007fe046cac000)
linux-vdso.so.1 => (0x00007fff71dff000)
libssl.so.10 => /usr/lib64/libssl.so.10 (0x000000323ca00000)
libcrypto.so.10 => /usr/lib64/libcrypto.so.10 (0x0000003237a00000)
libnsl.so.1 => /lib64/libnsl.so.1 (0x000000323c600000)
libc.so.6 => /lib64/libc.so.6 (0x000000322c200000)
libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x000000323a200000)
libkrb5.so.3 => /lib64/libkrb5.so.3 (0x0000003238200000)
libcom_err.so.2 => /lib64/libcom_err.so.2 (0x0000003237200000)
libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x0000003238a00000)
libdl.so.2 => /lib64/libdl.so.2 (0x000000322be00000)
libz.so.1 => /lib64/libz.so.1 (0x000000322da00000)
/lib64/ld-linux-x86-64.so.2 (0x000000322ba00000)
libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x0000003237600000)
libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x0000003238600000)
libresolv.so.2 => /lib64/libresolv.so.2 (0x000000322e200000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x000000322c600000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x000000322d600000)
i think don't have these 2 packages
but my problem is nagios is installed on redhat 6.2 Os and my nagios server don't have access to internet i have to install packages offline
what do i have to do ?
BR
- Former Nagios Staff
Those packages don't appear to be necessary on Cent6
Let's take a step back. This is a "server --> host" NRPE setup, not a "server --> passthrough --> Host" setup, correct? Is there any reason you can't use check_by_ssh? The check_by_ssh plugin will be more secure (but it does introduce more load). I suggest this because I know working through all of this on a system without Internet is a pain. https://assets.nagios.com/downloads/nag ... ng_SSH.pdf is for XI, but the mechanics are still the same.
Could you clarify the version of Red Hat you are using and where? You've mentioned 6.2, 6.4, and 6.8 in the thread. I'm not aware of any specific issues with specific versions, but if we are going to dig into that, we need to know what we are working with.
[root@centos6x64 ~]# ldd /usr/local/nagios/libexec/check_nrpe
linux-vdso.so.1 => (0x00007ffef7491000)
libssl.so.10 => /usr/lib64/libssl.so.10 (0x00007f4dd4f01000)
libcrypto.so.10 => /usr/lib64/libcrypto.so.10 (0x00007f4dd4b1d000)
libnsl.so.1 => /lib64/libnsl.so.1 (0x00007f4dd4903000)
libc.so.6 => /lib64/libc.so.6 (0x00007f4dd456f000)
libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007f4dd432b000)
libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007f4dd4043000)
libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007f4dd3e3f000)
libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007f4dd3c13000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f4dd3a0e000)
libz.so.1 => /lib64/libz.so.1 (0x00007f4dd37f8000)
/lib64/ld-linux-x86-64.so.2 (0x00007f4dd517a000)
libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007f4dd35ed000)
libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007f4dd33e9000)
libresolv.so.2 => /lib64/libresolv.so.2 (0x00007f4dd31cf000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f4dd2fb2000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f4dd2d92000)
dwhitfield wrote:Those packages don't appear to be necessary on Cent6Let's take a step back. This is a "server --> host" NRPE setup, not a "server --> passthrough --> Host" setup, correct? Is there any reason you can't use check_by_ssh? The check_by_ssh plugin will be more secure (but it does introduce more load). I suggest this because I know working through all of this on a system without Internet is a pain. https://assets.nagios.com/downloads/nag ... ng_SSH.pdf is for XI, but the mechanics are still the same.Code: Select all
[root@centos6x64 ~]# ldd /usr/local/nagios/libexec/check_nrpe linux-vdso.so.1 => (0x00007ffef7491000) libssl.so.10 => /usr/lib64/libssl.so.10 (0x00007f4dd4f01000) libcrypto.so.10 => /usr/lib64/libcrypto.so.10 (0x00007f4dd4b1d000) libnsl.so.1 => /lib64/libnsl.so.1 (0x00007f4dd4903000) libc.so.6 => /lib64/libc.so.6 (0x00007f4dd456f000) libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007f4dd432b000) libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007f4dd4043000) libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007f4dd3e3f000) libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007f4dd3c13000) libdl.so.2 => /lib64/libdl.so.2 (0x00007f4dd3a0e000) libz.so.1 => /lib64/libz.so.1 (0x00007f4dd37f8000) /lib64/ld-linux-x86-64.so.2 (0x00007f4dd517a000) libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007f4dd35ed000) libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007f4dd33e9000) libresolv.so.2 => /lib64/libresolv.so.2 (0x00007f4dd31cf000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f4dd2fb2000) libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f4dd2d92000)
so thanks
my means was nagios server is installed on Red Hat Enterprise Linux Server release 6.2 (Santiago)
and that server i want to add nagios is Red Hat Enterprise Linux Server release 6.8 (Santiago)
excuseme the correct output this is :
linux-vdso.so.1 => (0x00007ffc1cb59000)
libssl.so.10 => /usr/lib64/libssl.so.10 (0x0000003b48400000)
libcrypto.so.10 => /usr/lib64/libcrypto.so.10 (0x0000003b42800000)
libnsl.so.1 => /lib64/libnsl.so.1 (0x0000003b49400000)
libc.so.6 => /lib64/libc.so.6 (0x0000003b37000000)
libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x0000003b47400000)
libkrb5.so.3 => /lib64/libkrb5.so.3 (0x0000003b46400000)
libcom_err.so.2 => /lib64/libcom_err.so.2 (0x0000003b45400000)
libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x0000003b46c00000)
libresolv.so.2 => /lib64/libresolv.so.2 (0x0000003b38c00000)
libdl.so.2 => /lib64/libdl.so.2 (0x0000003b36c00000)
libz.so.1 => /lib64/libz.so.1 (0x0000003b37c00000)
/lib64/ld-linux-x86-64.so.2 (0x0000003b36800000)
libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x0000003b46800000)
libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x0000003b45c00000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x0000003b37400000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x0000003b38800000)
i don't have centos all of my os are redhat
now what do i have to do ?
will my problem solve?
CentOS and Red Hat should have package compatibility, so that's probably not the issue. AV sent you the package list for Cent/Red Hat 7, so that's why I sent the ones I had on 6...just to clarify that you didn't need the two you asked about.
You have two servers in our situation, so I think check_by_ssh should work for you. Do you just want to use NRPE because that is what you are using on your other servers? Did you look at https://assets.nagios.com/downloads/nag ... ng_SSH.pdf? We seem to be hitting a roadblock with NRPE, so I just want to be sure that's the only method that is going to work for you. http://www.techrepublic.com/blog/linux- ... sh-plugin/ gives a third-party view about check_by_ssh.
So thanksdwhitfield wrote:CentOS and Red Hat should have package compatibility, so that's probably not the issue. AV sent you the package list for Cent/Red Hat 7, so that's why I sent the ones I had on 6...just to clarify that you didn't need the two you asked about.
But i am so confused because i have added about 140 virtual machines (linux) with different version of redhat 4.2 , 6.4) to nagios server
And use nrpe for all of them why nrpe not work on this version of redhat(6.4)?
Is your means use check_by_ssh instead of check_nrpe for monitor this server?
BR
