HP iLO 2 Monitoring
Nagios_Admin_M
Re: HP iLO 2 Monitoring
Post by Nagios_Admin_M »
What I did is that:
I copied the source code of this plugin to the one of mines which works. The plugin returned "Service did not exit properly" as before.
Although, will try to advises as you suggested in the last post.
OK, post back your results.
Nagios_Admin_M
The snmpwalk was used instead of the script.
Thanks for reporting back. Shall we close and lock the post for you?
Nagios_Admin_M
Yes, please.
bolson
Post by bolson »
Closing topic as resolved.
Thank you for using the Nagios Support Forum.
