NRPE on Amazon Linux
cybergene
Re: NRPE on Amazon Linux
Post by cybergene »
I get this:
Starting up daemon
Apr  3 nrpe[22127]: There's already an NRPE server running (PID 22019).  Bailing out...
Apr  3 nrpe[22130]: Host 127.0.0.1 is not allowed to talk to us!
Apr  3 check_nrpe: Error: Could not complete SSL handshake with 127.0.0.1: rc=-1 SSL-error=5
I added localhost to nrpe.conf but the error still shows.
Is there a process running at PID 22019?
When the agent was started, it seems to think that NRPE was already running.
What user are you running all of these commands as? With NRPE barking about it running already I tend to believe it. If you're using a regular account with non-root privs this could be affecting it.
I'd consult whomever manages your linux systems to see if they can track it down.
cybergene
Post by cybergene »
There is :
nagios   22019  0.0  0.0  39628  1472 ?        Ss   Apr03   0:00 /usr/local/nagios/bin/nrpe -c /usr/local/nagios/etc/nrpe.cfg -d
Here:
ps -ef |grep nrpe
ec2-user 13729 13629  0 12:59 pts/0    00:00:00 grep nrpe
nagios   22019     1  0 Apr03 ?        00:00:00 /usr/local/nagios/bin/nrpe -c /usr/local/nagios/etc/nrpe.cfg -d
Tried this command:
./check_nrpe -H localhost -c check_load
CHECK_NRPE: Error - Could not connect to 127.0.0.1: Connection reset by peer
A couple of problems bound be causing the Connection Reset by peer messahe.
If the NRPE agent wasn't compiled with SSL, it could cause it. To test that our, try running this command if it works, then SSL was not compiled in to the agent.
./check_nrpe -H localhost -c check_load -n
Also, try running these variations of the command and see if they work.
./check_nrpe -H 127.0.0.1 -c check_load
./check_nrpe -H 127.0.0.1 -c check_load -4
If the nrpe.cfg file is not setup to allow the localhost address, that could cause it as well. Take a look at this file and verify that the 127.0.0.1 address is in the Allowed Hosts option.
If you need help, post the file here.
If you do any changes to the nrpe.cfg file, you will have to stop and start the daemon.
cybergene
Post by cybergene »
This command doesn't work, then SSL WAS compiled in to the agent.
[ec2-user@ip-10-95-33-53 libexec]$ ./check_nrpe -H localhost -c check_load -n
CHECK_NRPE: Receive header underflow - only -1 bytes received (4 expected).
[ec2-user@ip-10-95-33-53 libexec]$ ./check_nrpe -H 127.0.0.1 -c check_load -n
[ec2-user@ip-10-95-33-53 libexec]$ ./check_nrpe -H 127.0.0.1 -c check_load -4
[ec2-user@ip-10-95-33-53 libexec]$ ./check_nrpe -H localhost -c check_load -4
The /usr/local/nagios/etc/nrpe.cfg file contains:
allowed_hosts=127.0.0.1, ip,another ip
Other IPs to allow Nagios Core and agents to communicate over the network.
What steps did you do to compile in SSL to the NRPE Agent?
Did you rebuild the agent and the check_nrpe command and use them both during the testing?
Can you run the following commands on the Amazon server and post the output?
/usr/local/nagios/libexec/check_nrpe -V
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1 -c check_load
ps -ef |grep nrpe
Also, post this file as well.
cybergene
Post by cybergene »
Steps from here:https://support.nagios.com/kb/article.p ... ategory=22
Yes, I rebuild it again.
/usr/local/nagios/bin/nrpe :
te Plugin Executor
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 3.0.1
Last Modified: 09-08-2016
License: GPL v2 with exemptions (-l for more info)
SSL/TLS Available, OpenSSL 0.9.6 or higher required
** POSSIBLE SECURITY RISK - COMMAND ARGUMENTS ARE SUPPORTED! **
**      Read the NRPE SECURITY file for more information     **
** POSSIBLE SECURITY RISK - TCP WRAPPERS ARE NOT AVAILABLE!  **
Usage: nrpe [-n] -c <config_file> [-4|-6] <mode>
Options:
 -n               = Do not use SSL
 -c <config_file> = Name of config file to use
 -4               = use ipv4 only
 -6               = use ipv6 only
 <mode>           = One of the following operating modes:
   -i             =    Run as a service under inetd or xinetd
   -d             =    Run as a standalone daemon
   -d -s          =    Run as a subsystem under AIX
   -f             =    Don't fork() for systemd, launchd, etc.
Notes:
This program is designed to process requests from the check_nrpe
plugin on the host(s) running Nagios.  It can run as a service
under inetd or xinetd (read the docs for info on this), or as a
standalone daemon. Once a request is received from an authorized
host, NRPE will execute the command/plugin (as defined in the
config file) and return the plugin output and return code to the
check_nrpe plugin.
NRPE Plugin for Nagios
Version: 3.0.1
SSL/TLS Available: OpenSSL 0.9.6 or higher required
ps -ef |grep nrpe
ps -ef |grep nrpe
ec2-user 19170 13629  0 18:09 pts/0    00:00:00 grep nrpe
Lets stop and start the NRPE agent on the server by running the following as root
kill 22019
Then run this to test the Agent
If it fails, please post this file
cybergene
Post by cybergene »
It failed:
connect to address 127.0.0.1 port 5666: Connection refused
connect to host 127.0.0.1 port 5666: Connection refused
See attached.
nrpe.cfg
(10.14 KiB) Downloaded 552 times
