Windows Server Not Showing Memory Usage in Nagios Xi Metrics
da1701d
Re: Windows Server Not Showing Memory Usage in Nagios Xi Met
Post by da1701d »
mcapra wrote:@lmiltchev actually did some investigation into this, and it's a bug within the Metrics component that we're going to need to fix. A big re-work of that component to better include 3rd party plugins is currently on our to-do list.
I do apologize for the inconvenience. Let us know if you have additional questions regarding this.
Has anyone heard if the bug was fixed? I would like utilize the Metrics feature.
Dan
Dan,
some of the issues with the Metrics component have been fixed already, others - not yet. Currently, custom memory checks with check_nrpe and NSClient++ won't show up in the Metrics. Only the check_nt checks will. Our developers are planning on re-writing the component but I don't have an ETA on that.
Having said that, are you having any specific issue with the Metrics component that you are troubleshooting at the moment?
da1701d
Post by da1701d »
Dan,
Only issue is that it hardly shows any servers with data but we mostly use the newer NCPA nagios agent (using that check_ncpa.py plugin) to basic system health checks. I was hoping to use the Metric feature to report on checks for cpu, memory, and disk checks that are done by the newer NCPA nagios agent, but I'm unable to find the systems included in metric data that use this newer agent. I'm kind of bummed. My boss has wants metrics pulled for a lot of things.
Dan
da1701d wrote:Only issue is that it hardly shows any servers with data but we mostly use the newer NCPA nagios agent (using that check_ncpa.py plugin) to basic system health checks. I was hoping to use the Metric feature to report on checks for cpu, memory, and disk checks that are done by the newer NCPA nagios agent, but I'm unable to find the systems included in metric data that use this newer agent. I'm kind of bummed. My boss has wants metrics pulled for a lot of things.
The last round of additions to the metrics component were before ncpa was fully developed. I will add a feature request to add the NCPA wizard defaults to the metrics component.
sarfarosh
Post by sarfarosh »
Hi Team,
Any update on this ? Client has came back with the issue to get it resolved as we was supposed to provide the solution in july release of update.
kyang
Post by kyang »
Sorry to say, but this is still currently in the works under our internal task_id=12576
da1701d
Post by da1701d »
kyang wrote:Sorry to say, but this is still currently in the works under our internal task_id=12576
Any idea when this will get fixed?
kyang
Post by kyang »
There is no exact ETA as of now. We are working on XI 5.5 since it's due to be released around Q1 of 2018.
I would check back around that time.
https://www.nagios.com/roadmaps/
sarfarosh
Post by sarfarosh »
Hi Team,
We are unable to respond back positively to client on this issue as its reported many months back and yet not fixed. Please provide some timeline on fixing this one.
Post by dwhitfield »
scottwilkerson wrote:I will add a feature request
Unfortunately, a request is a request. This may never happen. We have not yet approved this feature for inclusion and cannot give you a timeline for when it may be included. You can follow the changelog at https://assets.nagios.com/downloads/nag ... NGES-5.TXT
