Unable to write to check_result_path
pratik.patel
Re: Unable to write to check_result_path
Post by pratik.patel »
Have a look at error logs when trying to download system profile :
/bin/mkdir: cannot create directory '/usr/local/nagiosxi/var/components/profile': Permission denied
[Tue May 16 10:08:09.949912 2017] [:error] [pid 19734] [client 10.0.2.208:52818] PHP Warning: unlink(/usr/local/nagiosxi/tmp/ccm_index.tmp): No such file or directory in /usr/local/nagiosxi/html/includes/components/profile/profile.php on line 299, referer: http://nagiosxi.xxxxxxx.com/nagiosxi/in ... rofile.php
[Tue May 16 10:08:09.958226 2017] [:error] [pid 19734] [client 10.0.2.208:52818] PHP Warning: file_put_contents(/usr/local/nagiosxi/var/components/profile/profile.txt): failed to open stream: No such file or directory in /usr/local/nagiosxi/html/includes/components/profile/profile.php on line 315, referer: http://nagiosxi.xxxxxxx.com/nagiosxi/in ... rofile.php
sudo: unable to open audit system: Permission denied
On my Linux machine:
[root@xxxxxxxxxx components]# ls -dZ /usr/local/nagiosxi/var/components
drwsrwsr-x. apache nagios unconfined_u:object_r:usr_t:s0 /usr/local/nagiosxi/var/components
pratik.patel wrote:Have a look at error logs when trying to download system profile :
Can you try this with SELinux not enforcing.
As was pointed out earlier
We do not support SELinux in enforcing, but if you have an SELinux expert in your organization, they may be able to get it working.
https://support.nagios.com/kb/article/n ... rface.html
pratik.patel
ok..
Post by dwhitfield »
Does it work when SELinux is not in enforcing? If so, are we ready to lock the thread?
pratik.patel
Yes it works fine when selinux is permissive/disabled.
