Regarding the error
2017-06-11 18:53:23 [29545] [1] Cant find Nagios Environment. Exiting ....
look like that error is from yesterday.
I have made the time zone changes. I am not seeing the warning anymore
I also changed the setting to 0
lastly I am not using nagiosramdisk, and I dont think I need that because is a very small nagios instance. where in the config are you seeing that?
Fresh install
Re: Fresh install
I saw that the system does have a ramdisk mounted on the system.
Some of the settings on the system are using the ramdisk so if you do not want to use it, edit the commands by following this process
Login to Nagios XI and navigate to Configure > Core Config Manager > Commands > _Commands menu.
In the search field type file-bulk and press Enter.
The screen will update with the two commands process-host-perfdata-file-bulk and processservice- perfdata-file-bulk.
Both of these commands need to be updated with the non-ramdisk directory locations.
This command
needs to be changed to
and
This command
Save the commands and apply the config. That should fix the performance graphs for you.
This command
process-host-perfdata-file-bulkCode: Select all
command_line /bin/mv /usr/local/nagios/var/host-perfdata /usr/local/nagios/var/spool/xidpe/$TIMET$.perfdata.hostThis command
process-service-perfdata-file-bulkCode: Select all
command_line /bin/mv /usr/local/nagios/var/service-perfdata /usr/local/nagios/var/spool/xidpe/$TIMET$.perfdata.serviceBe sure to check out our Knowledgebase for helpful articles and solutions!
Re: Fresh install
Thanks a lot. I think I know what probably happened. Although this is a fresh install I did imported the .cfg files from another instance including the commands.cfg. the the instance that I imported the configs from we are using ramdisk.
I soon I changed I was able to see the performance data.
Thanks a lot.
we can close this ticket now
Thanks a lot.
