Problem with NDOUtils
Re: Problem with NDOUtils
Not knowing completely how this was installed we could hit other problems, however from inside the db directory you may be able to do the following:
sed -i "s/TYPE/ENGINE/g" ./*.sql
When these scripts were written 10 years ago the TYPE directive was proper however it has been switched to ENGINE and type was deprecated in MySQL/Mariadb 5.5
Cristhian_Plaza
Post by Cristhian_Plaza »
scottwilkerson wrote:Not knowing completely how this was installed we could hit other problems, however from inside the db directory you may be able to do the following:
Ok.., now jajaajja we are having progress although I got another error.., I think this is easiest to solve. What can you tell me about the error?
[root@ip-10-0-8-150 db]# ./upgradedb -u xxxx -p xxxx -h localhost -d xxxx
Current database version: 1.4b2
** DB upgrade required for 1.4b3
     Using mysql-upgrade-1.4b3.sql for upgrade...
ERROR 1060 (42S21) at line 123: Duplicate column name 'last_state'
Upgrade from mysql-upgrade-1.4b3.sql failed at ./upgradedb line 106.
We need to stop for a minute, the command is listing
But previously you showed that ndo2db version was 2.1.2
At this point, if it has never actually worked correctly, and you do not have data that you risk losing, I would highly recommend NOT doing the upgrade, and remove the existing database, and running the install script instead
mysql -u root -p
> DROP DATABASE nagios;
> CREATE DATABASE nagios;
Create a username/password that has at least the following privileges for the database:
SELECT, INSERT, UPDATE, DELETE
then:
./installdb  -u xxxx -p xxxx -h localhost -d xxxx
