Postfix for nagios email notification alerts problem
Siddharth Hegde
Re: Postfix for nagios email notification alerts problem
Post by Siddharth Hegde »
Hi @tgriep,
I have checked
command[check_usolved_disks]=/usr/bin/php /usr/local/nagios/libexec/check_usolved_disks.php -H host.private.ip.address -C public -V 2c -w 90 -c 95
and
command[check_usolved_disks]=/usr/bin/php /usr/local/nagios/libexec/check_usolved_disks.php -H host.private.ip.address -C public -V 1 -w 90 -c 95
Still getting
Unknown - Could't read SNMP information. Properly the host isn't configured correctly for SNMP or wrong SNMP version was given.
The only thing I can think is left is that the device is not setup to be polled with SNMP.
Check the settings and verify that the community string is correct, that the SNMP version is correct and that there is not a firewall or access list blocking the polls.
Siddharth Hegde
Hi @tgriep,
Thanks. I'll think of something else. I'll try to use check_disk and tweak it to use for other disk checks also.
Post by dwhitfield »
If you end up with a non-snmp issue, please start a new thread. We'll leave this open in case you need to go back to SNMP.
