Even with recreating all of the recurring maintenance they are still not working.
What am i to do right now. The current state of nagios XI and recurring maintenance not working is not good.
Recurring Maintenance not working
Re: Recurring Maintenance not working
Recreating the entries for recurring downtime was supposed to re-add the entries but I guess doing that, did not work in all cases.
The next release of XI should fix the issue.
What you should do it to edit the /etc/cron.d/nagiosxi file and comment out the php version of the Recurring Downtime script by changing this line from
to
Save the file and restart crom by running
When the next version of XI comes out, you will have to undo this change and also remove the Perl version on the from the cron tab file.
01 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/recurring_downtime.php >> /usr/local/nagiosxi/var/recurringdowntime.log 2>&1Code: Select all
# 01 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/recurring_downtime.php >> /usr/local/nagiosxi/var/recurringdowntime.log 2>&1Code: Select all
service crond restartBe sure to check out our Knowledgebase for helpful articles and solutions!
