snmptt wont startx
Re: snmptt wont startx
I am not using postgres
First, lets see if there are any errors generated when the test is ran.
Run this as root
Then run the test again and if you see any errors in the tail window, post them here.
If you do not see any errors, we would need to see the SNMP configuration files and the MIB files from the server so can you run the following 3 commands as root.
Then post these 3 files so we can check the settings and the MIB files for any errors.
Also, we would need to see the database settings so run the following as root and post the /tmp/trap.txt file
Run this as root
tail -f /var/log/httpd/*_logIf you do not see any errors, we would need to see the SNMP configuration files and the MIB files from the server so can you run the following 3 commands as root.
tar cvfz /tmp/snmp.tgz /etc/snmp/*
tar cvfz /tmp/sharesnmp.tgz /usr/share/snmp/mibs/*
tar cvfz /tmp/snmplog.tgz /var/log/snmptt/*Code: Select all
/tmp/snmp.tgz
/tmp/sharesnmp.tgz
/tmp/snmplog.tgzCode: Select all
echo 'select * from xi_cmp_trapdata;' |mysql -u root -pnagiosxi nagiosxi >/tmp/trap.txt
echo 'select * from xi_cmp_trapdata_log;' |mysql -u root -pnagiosxi nagiosxi >>/tmp/trap.txtBe sure to check out our Knowledgebase for helpful articles and solutions!
here you go
The /etc/snmptt.ini file was not changed when the XI upgrade process ran so the nxti settings were not updated (Permission issue).
To fix this, run the following as root to fix the permissions
Then edit the /etc/snmptt.ini file and change this from
to
Save the file and restart the Trap daemon
Login to the XI GUI and go to the Trap interface and delete the Test Trap configurations and any received traps.
Then try the test again and see if it works.
chown nagios.nagios /etc/snmptt.ini
chmod 664 /etc/snmptt.ini
snmptt_conf_files = <<END
/etc/snmp/snmptt.conf
END
/etc/snmp/snmptt.conf.nxti
ENDCode: Select all
service snmptt restartThen try the test again and see if it works.
Run these commands as root in a shell.
Go to the SNMP Trap interface menu, click on the Advanced Tab.
Click on the Restore SNMPTT Configuration button.
Then run this as root in a shell.
Click on the One Click test and post any errors from the tail shell.
Other than the One Click issue, can you Define a Trap in the menu?
chown -R nagios.nagios /usr/share/snmp/mibs
chmod 664 /usr/share/snmp/mibs
chown nagios.nagios /etc/snmptt.conf
chmod 664 /etc/snmptt.confClick on the Restore SNMPTT Configuration button.
tail -f /var/log/httpd/*_logOther than the One Click issue, can you Define a Trap in the menu?
I am getting this error
Cannot rename /var/lib/net-snmp/snmpapp.conf to /var/lib/net-snmp/snmpapp.0.conf
Cannot unlink /var/lib/net-snmp/snmpapp.conf
[Thu Aug 09 09:56:44.924674 2018] [:error] [pid 82793] [client 10.144.2.183:10825] PHP Notice: Undefined variable: restart in /usr/local/nagiosxi/html/includes/components/nxti/index.php on line 0, referer: http://nagiosxi/nagiosxi/includes/compo ... /index.php
[Thu Aug 09 09:57:10.744623 2018] [:error] [pid 36780] [client 10.144.1.77:37754] PHP Notice: Array to string conversion in /usr/local/nagiosxi/html/includes/utils-xmlstatus.inc.php on line 1386, referer: http://nagiosxi/nagiosxi/dashboards/dashboard.php?&=
[Thu Aug 09 09:57:46.811355 2018] [:error] [pid 5999] [client 10.144.2.183:11009] PHP Notice: Array to string conversion in /usr/local/nagiosxi/html/includes/utils-xmlstatus.inc.php on line 1386, referer: http://nagiosxi.bose.com/nagiosxi/dashb ... ard.php?&=
[Thu Aug 09 09:58:07.857602 2018] [:error] [pid 79717] [client 10.144.2.183:11069] PHP Notice: Undefined variable: restart in /usr/local/nagiosxi/html/includes/components/nxti/index.php on line 0, referer: http://nagiosxi/nagiosxi/includes/compo ... /index.php
[Thu Aug 09 09:58:40.817754 2018] [:error] [pid 99104] [client 10.144.1.77:37982] PHP Notice: Array to string conversion in /usr/local/nagiosxi/html/includes/utils-xmlstatus.inc.php on line 1386, referer: http://nagiosxi/nagiosxi/dashboards/dashboard.php?&=
[Thu Aug 09 09:58:47.206981 2018] [:error] [pid 23290] [client 10.144.2.183:11153] PHP Notice: Undefined variable: restart in /usr/local/nagiosxi/html/includes/components/nxti/index.php on line 0, referer: http://nagiosxi/nagiosxi/includes/compo ... /index.php
Thanks for the output.
It looks like the permissions for that file and folders need to be reset.
Run this as root to fix that.
Then test it again.
chown -R nagios.nagios /var/lib/net-snmp
chmod -R 775 /var/lib/net-snmpBe sure to check out our Knowledgebase for helpful articles and solutions!
get this error
[Thu Aug 09 10:45:31.980012 2018] [:error] [pid 96705] [client 10.144.1.77:44862] PHP Notice: Undefined variable: restart in /usr/local/nagiosxi/html/includes/components/nxti/index.php on line 0, referer: http://nagiosxi/nagiosxi/includes/compo ... /index.php
That is not an error, it is only a PHP Notice so you can ignore it.
