Nagios process at 100% CPU, system is crawling
amprantino
Re: Nagios process at 100% CPU, system is crawling
Post by amprantino »
I am facing the same issue after upgrading to version 4.4.1
CGI scripts reach 100% cpu, apache2 response is really slow and the nagios site is not responding.
New comments are also saved numerous times in the files.
I had to delete retention.dat & status.dat, loosing the state of everything and creating a mess with notifications.
At the moment the only workaroud is informing users not to post comments.
Is there a plan for a fix or any workaround for version 4.4.1 ?
Thank you
The maint branch has all of this resolved
https://github.com/NagiosEnterprises/na ... tree/maint
But also make sure you don't have multiple nagios parent processes running.
ps -ef|grep nagios.cfg
amprantino
Yes, its fixed
Best Regards
amprantino wrote:Yes, its fixed
Best Regards
Locking
