CHECK_NRPE: Error
BrunoLosse1
Re: CHECK_NRPE: Error
Post by BrunoLosse1 »
@npolovenko same error.
nsclient.log
(607.79 KiB) Downloaded 661 times
benjaminsmith
Post by benjaminsmith »
Hello @BrunoLosse1
We're really not quite sure why your still having this error condition. We've discussed the issue here and believe we may have better results using an earlier version of NSClient. Let's try the following:
1. Backup your current configuration file (nsclient.ini).
2. Uninstall NSClient++
3. Remove any remaining directories in C:\Program Files for NSClient++
4. Install NSClient 0.4.4 along with your backup configuration file.
https://www.nsclient.org/download/0.4.4
5. Test again
If you're still getting the same error, then please post the current configuration file again for us to review again.
BrunoLosse1
Hello @benjaminsmith,
Same error.
Reinstalled without changing anything in the .ini, what should I change?
nsclient.ini
(981 Bytes) Downloaded 655 times
nsclient.log
(1.7 KiB) Downloaded 668 times
benjaminsmith
Hi @BrunoLosse1
It looks like you're still getting the ssl handshake error ( 2018-11-19 12:02:23: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: sslv3 alert handshake failure: 1040). Make sure to change the ssl options to:
ssl options =
and restart. If this doesn't work, please use the attached ini file. This is the minimum configuration file for nsclient that we have used with other customers.
nsclient.ini
(903 Bytes) Downloaded 802 times
BrunoLosse1
I'm getting connection refused with the ini you provided.
nsclient.log
(15.35 KiB) Downloaded 634 times
benjaminsmith
We've tested this here with NSClient 0.4.4 and the last nsclient.ini file, and it's working. What version of check_nrpe do you have installed?
cd /usr/local/nagios/libexec
./check_nrpe -V
nsclient.ini
; Undocumented section
[/settings/default]
; Undocumented key
password = TIAtende07
; Undocumented key
allowed hosts = 10.63.248.131
[/settings/NRPE/server]
allow arguments = 1
allow nasty characters = 1
use SSL = 1
insecure = 1
[/modules]
; Undocumented key
CheckExternalScripts = 1
; Undocumented key
CheckHelpers = 1
; Undocumented key
CheckEventLog = 1
; Undocumented key
CheckNSCP = 1
; Undocumented key
CheckDisk = 1
; Undocumented key
CheckSystem = 1
; Undocumented key
NSClientServer = 1
; Undocumented key
NRPEServer = 1
[/settings/external scripts]
allow arguments=1
allow nasty characters=true
[/settings/log/file]
max size = -1
[/settings/log]
level = debug
file name = ${exe-path}/nsclient.log
date format = %Y-%m-%d %H:%M:%S
BrunoLosse1
@benjaminsmith,
administrator@GEUL3BNAGPAS01:/usr/local/nagios/libexec$ ./check_nrpe -V
NRPE Plugin for Nagios
Version: 3.2.1
Lets start over with the NSClient Install again as I feel there may be a bad SSL key file.
Uninstall the NSClient++ agent on the windows server and delete the following folder.
C:\Program Files\NSClient++
Download and install the latest stable 0.4.4.xx version of the NSClient++ service.
Replace the C:\Program Files\NSClient++\nsclient.ini file with the one attached to the post.
Edit the ini file and update the following line with the IP address of the Nagios server and restart NSClient++
allowed hosts = xxx.xxx.xxx.xxx
Let us know if this works out not.
nsclient.ini
(1.9 KiB) Downloaded 698 times
BrunoLosse1
@tgriep, sorry for taking that long to respond.
No, it did not work.
nsclient.log
(471.63 KiB) Downloaded 660 times
Can you login to the nagios server as root, run the following command and post the output here?
ldd /usr/local/nagios/libexec/check_nrpe
