Configuring NRPE client CentOS7
Re: Configuring NRPE client CentOS7
How about this
/usr/local/nagios/libexec/check_nrpe -2 -H 10.128.207.115 -c check_services -t 30 -a 'elasticsearch'
rferebee
Post by rferebee »
Yes, that works.
[rferebee@nagiosxi ~]$ sudo su -
root@nagiosxi> /usr/local/nagios/libexec/check_nrpe -2 -H 10.128.207.115 -c check_services -t 30 -a 'elasticsearch'
elasticsearch: 1
So, a little background. I was told by someone on your end that the command we were using for check_nrpe was not the default and they suggested I change it to the default so when I run the Linux Server wizard it will use the correct command.
I'm guessing that -a has something to do with our issue?
Yes, you need to pass -a when running check_nrpe which tells the command what follows is the argument
This is usually passed in the $ARG1$ of the service
-a 'elasticsearch'
rferebee
Post by rferebee »
Ok, so here's the command we're using for check_nrpe:
$USER1$/check_nrpe -2 -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
Where should I add the -a?
ssax
Dreams In Code
Post by ssax »
With this definition:
You would need to go to Configure > Core Config Manager > Services in the XI server and add this to your $ARG2$:
-a 'elasticsearch'
Save, Apply Config, Test, let us know the results.
$ARG1$ is your NRPE command, $ARG2$ is a placeholder for anything else you want to pass such as arguments or any other check_nrpe argument from:
/usr/local/nagios/libexec/check_nrpe -h
rferebee
Post by rferebee »
So, can I just do this?
$USER1$/check_nrpe -2 -H $HOSTADDRESS$ -t 30 -c $ARG1$ -a $ARG2$
I would highly recommend this
then is your services youu would set
$ARG1$ =
check_services
$ARG2$ =
-a 'elasticsearch'
rferebee
Post by rferebee »
This thread can be closed. Thank you.
rferebee wrote:This thread can be closed. Thank you.
Great!
Locking
