Hosts and services temporarily unavailable
drug
Re: Hosts and services temporarily unavailable
Post by drug »
ssax wrote: That is correct, I only know this because I had the very discussion with the head of development when working a bug in the CCMs permissions building and until NDOUtils is removed from the architecture, you can count on this being the case:
Expect up to a 3 minute delay after an Apply Configuration (at the minimum)
depending on how many objects/records in the DB/total checks/active vs inactive/load/DB offloaded/ etc, they all have an impact
I guess that answers my question then but not exactly what I was hoping to hear. I notice that you said, until NDOUtils is removed from the architecture. Does that mean there are plans to remove/replace NDOUtils or otherwise make changes to eliminate this issue? :D
ssax
Dreams In Code
Post by ssax »
It is on the developers roadmap, they are redoing parts of it as we speak and that should increase the performance but there's no ETA for when NDOUtils goes away at this point in time and the changes they are working on are still a bit out (months).
drug
Post by drug »
Thank you all for your help! I look forward to future performance improvements; meanwhile we'll make adjustments where we can to speed up the configuration application process. This may be closed.
