(Return code of 127 is out of bounds - plugin may be missing
kmartin2007
Re: (Return code of 127 is out of bounds - plugin may be mis
THat is the check_url
command_name check_url
command_line $USER1$/check_url.pl $ARG1$
use production-service
host_name AWSSRVPRDIIS01
service_description ESPDATA.ORG.AU
check_command check_url!http://www.espdata.org.au/index.asp
Ok, lets run the following and post the output
su nagios -c '/usr/local/nagios/libexec/check_url.pl http://www.espdata.org.au/index.asp; echo $?'-
kmartin2007
root@dalsrvitmon03:/usr/local/nagios/libexec# su nagios -c '/usr/local/nagios/libexec/check_url.pl http://www.espdata.org.au/index.asp; echo $?'
This account is currently not available.
hmmm i think i know what this is, but not 100%. maybe we dont have an account configured on the local server maybe?
Something is wrong with the nagios user account
can you just su to the account?
is it expired?
su nagiosCode: Select all
chage -l nagios-
kmartin2007
scottwilkerson wrote:Something is wrong with the nagios user account
can you just su to the account?is it expired?Code: Select all
chage -l nagios
I dont remember ever setting this password when using apt install to install nagios3 core
ozadmin@dalsrvitmon03:~$ su nagios
Password:
su: Authentication failure
ozadmin@dalsrvitmon03:~$ chage -l nagios
chage: Permission denied.
ozadmin@dalsrvitmon03:~$ sudo -s
[sudo] password for ozadmin:
root@dalsrvitmon03:~# chage -l nagios
Last password change : Nov 12, 2019
Password expires : never
Password inactive : never
Account expires : never
Minimum number of days between password change : 0
Maximum number of days between password change : 99999
Number of days of warning before password expires : 7
can you su nagios once you are root?
there should be no password on the nagios account unless you set one
su nagios-
kmartin2007
scottwilkerson wrote:can you su nagios once you are root?
there should be no password on the nagios account unless you set oneCode: Select all
su nagios
root@dalsrvitmon03:~# su nagios
You may want to try to change the shell for the nagios user
usermod --shell /bin/bash nagios-
kmartin2007
that worked
nagios@dalsrvitmon03:/usr/local/nagios/libexec$
kmartin2007
Still says password is bad, no password was entered
ozadmin@dalsrvitmon03:~$ su nagios -c '/usr/local/nagios/libexec/check_url.pl http://www.espdata.org.au/index.asp; echo $?'
Password:
Password:
Password:
Password:
