CHECK_NRPE : Error : Connection Reset by Peer
Re: CHECK_NRPE : Error : Connection Reset by Peer
Post by Box293 »
amitgupta19
Post by amitgupta19 »
Thanks Box293
After installing the Agent again on the server,it is reporting fine in Nagios.
Only Check Disk All is giving the following error:
CHECK_NRPE: Receive header underflow - only -1 bytes received (4 expected).
What should we do.
amitgupta19
Please ignore it.
It has been resolved. I had changed the command to no SSL.
/check_nrpe -n no-ssl -H $HOSTADDRESS$ -c $ARG1$
Now i reverted it to the Default, and it is working Now.
Thanks Everyone for your continued support.
amitgupta19 wrote:Please ignore it.
Great!
Locking thread
