This is the original script that I tried to use. However, the script is not running as you would expect and the output is a mess not what we really needed, thus I rewrote to script to fit our needs.
May be I'll give the original script another go and if that's working rather "correct" the original script as I am really lost with this either.
Anyway, thanks for your help!
Cheers,
Dennis
jstat is failing to show a proper result
runzelpunzel
Re: jstat is failing to show a proper result
Best of luck!runzelpunzel wrote:This is the original script that I tried to use. However, the script is not running as you would expect and the output is a mess not what we really needed, thus I rewrote to script to fit our needs.
Cheers,
Dennis
