Need help configuring SSL with Nagios XI
Re: Need help configuring SSL with Nagios XI
Can you attach your nagiosxi.comf file
File is attached.
Sorry here it is. Just rename file to .conf. Thanks.
Lets replace the commented out section with the following:
<VirtualHost *:443>
<Directory "/usr/local/nagiosxi/html">
SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# Allow from 127.0.0.1
# AuthName "Nagios XI"
# AuthType Basic
# AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
# Require valid-user
</Directory>
</VirtualHost>Re: Need help configuring SSL with Nagios XI
What about the portion below the commented out section? Do I leave that there?
After making the chage, httpd failed to start. Below is the current nagiosxi.conf and the httpd log.
nagiosxi.conf
<VirtualHost *:443>
SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# AuthType Basic
</Directory>
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile /etc/pki/tls/certs/ca.crt
SSLCertificateKeyFile /etc/pki/tls/private/ca.key
AllowOverride All
</Directory>
</VirtualHost>
Alias /nagiosxi "/usr/local/nagiosxi/html"
Log:
[Fri May 25 08:49:21 2012] [notice] caught SIGTERM, shutting down
[Fri May 25 08:49:22 2012] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri May 25 08:49:22 2012] [error] Server should be SSL-aware but has no certificate configured [Hint: SSLCertificateFile] (/etc/httpd/conf.d/nagiosxi.conf:1)
nagiosxi.conf
<VirtualHost *:443>
SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# AuthType Basic
</Directory>
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
AllowOverride All
</Directory>
</VirtualHost>
Log:
I'm sorry the section at the top should be
I accidentally left :443 in there and it should be :80<VirtualHost *:80>
SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# AuthType Basic
</Directory>
</VirtualHost>
Ok that worked - httpd started.
However, when I access nagiosxi via http, I get the the "Welcome" page (attached) where it has a broken NagiosXI image. Then when I click on "Acess Nagios XI", I get the "Forbidden" page.
Is there a way to bypass the "Welcome" page when a user tries to access Nagiosxi and have redirected straight to the "Forbidden" page.
Thank you.
Thank you.
When you navigate to: Admin->System Config->Mange System Config, what do you see in the "Program URL" field? I guess you have: "https://<IP_address>" but you should have "https://<IP_address>/nagiosxi/" instead. You should modify this field and hit the "Update Settings" button.
Hope this helps.
Hope this helps.
