Nagios ramdisk full and no performance graphs
hbouma
Re: Nagios ramdisk full and no performance graphs
Post by hbouma »
Support file sent via PM.
pbroste wrote: Looking back through we see that you stated that the following directory is not created when the 'ramdisk.service' is started and wanted to touch on this further, by taking a look at the journal output on restarted service.
First restart the 'ramdisk.service' by:
systemctl restart ramdisk.service
Then take a look at the 'systemctl' status to see if the '/var/nagiosramdisk/spool/xidpe' folder is create or missed?
systemctl -l status ramdisk --no-pager
I do not see it making a /var/nagiosramdisk/spool/xidpe folder.
● ramdisk.service - Ramdisk
   Loaded: loaded (/usr/lib/systemd/system/ramdisk.service; enabled; vendor preset: disabled)
   Active: active (exited) since Mon 2021-11-22 11:44:45 EST; 18s ago
  Process: 14008 ExecStart=/usr/bin/chown -R nagios:nagios /var/nagiosramdisk (code=exited, status=0/SUCCESS)
  Process: 14004 ExecStartPre=/usr/bin/mkdir -p -m 775 /var/nagiosramdisk/tmp/var/nagiosramdisk/spool /var/nagiosramdisk/spool/checkresults/var/nagiosramdisk/spool/xidpe /var/nagiosramdisk/spool/perfdata (code=exited, status=0/SUCCESS)
  Process: 14001 ExecStartPre=/usr/bin/mount -t tmpfs -o size=500m tmpfs /var/nagiosramdisk (code=exited, status=0/SUCCESS)
  Process: 13998 ExecStartPre=/usr/bin/mkdir -p -m 775 /var/nagiosramdisk (code=exited, status=0/SUCCESS)
 Main PID: 14008 (code=exited, status=0/SUCCESS)
Nov 22 11:44:45 SERVER systemd[1]: Starting Ramdisk...
Nov 22 11:44:45 SERVER systemd[1]: Started Ramdisk.
pbroste wrote: Also, let us know how 'rrdcached.service' looks as well.
systemctl -l status rrdcached --no-pager
Perry
Here is the output:
● rrdcached.service - LSB: start and stop rrdtool caching daemon
   Loaded: loaded (/etc/rc.d/init.d/rrdcached; bad; vendor preset: disabled)
   Active: active (running) since Tue 2021-11-16 07:56:23 EST; 6 days ago
     Docs: man:systemd-sysv-generator(8)
   CGroup: /system.slice/rrdcached.service
           └─21288 /usr/bin/rrdcached -p /var/rrdtool/rrdcached/rrdcached.pid -s nagios -m 0660 -l unix:/var/rrdtool/rrdcached/rrdcached.sock -F -w 900 -z 90 -j /var/rrdtool/rrdcached -b /var/rrdtool/rrdcached
Nov 22 08:56:23 SERVER rrdcached[21288]: started new journal /var/rrdtool/rrdcached/rrd.journal.1637589383.218497
Nov 22 08:56:23 SERVER rrdcached[21288]: removing old journal /var/rrdtool/rrdcached/rrd.journal.1637582183.218593
Nov 22 09:56:23 SERVER rrdcached[21288]: flushing old values
Nov 22 09:56:23 SERVER rrdcached[21288]: rotating journals
Nov 22 09:56:23 SERVER rrdcached[21288]: started new journal /var/rrdtool/rrdcached/rrd.journal.1637592983.218610
Nov 22 09:56:23 SERVER rrdcached[21288]: removing old journal /var/rrdtool/rrdcached/rrd.journal.1637585783.218568
Nov 22 10:56:23 SERVER rrdcached[21288]: flushing old values
Nov 22 10:56:23 SERVER  rrdcached[21288]: rotating journals
Nov 22 10:56:23 SERVER  rrdcached[21288]: started new journal /var/rrdtool/rrdcached/rrd.journal.1637596583.218546
Nov 22 10:56:23 SERVER rrdcached[21288]: removing old journal /var/rrdtool/rrdcached/rrd.journal.1637589383.218497
pbroste
Post by pbroste »
Hello @hbouma
Thanks for sending over the info, from what we can see from the results it appears from the 'ramdisk.service' startup that all directories are created ('/var/nagiosramdisk/spool/xidpe'). Please send the list on the directories after restarting ramdisk.service:
ls -lahrtR /var/nagiosramdisk/
Perry
hbouma
Post by hbouma »
FYI, the Nagios RAMDISK has started filling up again.
12:55 PM SERVER root [~]
$ systemctl restart ramdisk.service
/var/nagiosramdisk/:
total 4.0K
drwxr-xr-x. 24 root   root   4.0K Mar 29  2019 ..
drwxr-xr-x   3 nagios nagios   60 Nov 23 12:55 tmp
drwxr-xr-x   4 nagios nagios   80 Nov 23 12:55 spool
drwxrwxrwt   4 nagios nagios   80 Nov 23 12:55 .
/var/nagiosramdisk/tmp:
total 0
drwxr-xr-x 3 nagios nagios 60 Nov 23 12:55 var
drwxrwxrwt 4 nagios nagios 80 Nov 23 12:55 ..
drwxr-xr-x 3 nagios nagios 60 Nov 23 12:55 .
/var/nagiosramdisk/tmp/var:
total 0
drwxr-xr-x 3 nagios nagios 60 Nov 23 12:55 nagiosramdisk
drwxr-xr-x 3 nagios nagios 60 Nov 23 12:55 ..
/var/nagiosramdisk/tmp/var/nagiosramdisk:
total 0
drwxrwxr-x 2 nagios nagios 40 Nov 23 12:55 spool
/var/nagiosramdisk/tmp/var/nagiosramdisk/spool:
total 0
drwxrwxr-x 2 nagios nagios 40 Nov 23 12:55 .
total 0
drwxrwxr-x 2 nagios nagios 40 Nov 23 12:55 perfdata
drwxr-xr-x 3 nagios nagios 60 Nov 23 12:55 checkresults
drwxr-xr-x 4 nagios nagios 80 Nov 23 12:55 .
/var/nagiosramdisk/spool/perfdata:
total 0
drwxr-xr-x 4 nagios nagios 80 Nov 23 12:55 ..
/var/nagiosramdisk/spool/checkresults:
total 0
/var/nagiosramdisk/spool/checkresults/var:
total 0
/var/nagiosramdisk/spool/checkresults/var/nagiosramdisk:
total 0
drwxr-xr-x 3 nagios nagios 60 Nov 23 12:55 spool
/var/nagiosramdisk/spool/checkresults/var/nagiosramdisk/spool:
total 0
drwxrwxr-x 2 nagios nagios 40 Nov 23 12:55 xidpe
/var/nagiosramdisk/spool/checkresults/var/nagiosramdisk/spool/xidpe:
total 0
Looking directly at /var/nagiosramdisk/spool, I do not see an xidpe. however, I do see a /var/nagiosramdisk/spool/checkresults/var/nagiosramdisk/spool/xidpe folder
2:56 PM SERVER root [~]
$ cd /var/nagiosramdisk/spool/
12:56 PM SERVER root [/var/nagiosramdisk/spool]
$ ll
total 0
drwxrwxrwt 4 nagios nagios 140 Nov 23 12:56 ..
pbroste
Post by pbroste »
Hello @hbouma
We see that the '/etc/init.d/nagios' and 'ramdisk.service' are calling for ramdisk start-up and want to disable the one found in /etc/init.d/nagios by commenting out following lines:
Please create a backup before editing:
cp /etc/init.d/nagios /tmp/nagios.bak
Here are the lines that should be commented out with '#':
# Automate addition of RAMDISK based on environment variables
#USE_RAMDISK=${USE_RAMDISK:-0}
#if test "$USE_RAMDISK" -ne 0 && test "$RAMDISK_SIZE"X != "X"; then
# ramdisk=`mount |grep "${RAMDISK_DIR} type tmpfs"`
# if [ "$ramdisk"X == "X" ]; then
# if [ ! -d ${RAMDISK_DIR} ]; then
# mkdir -p -m 0755 ${RAMDISK_DIR}
# if [ -d ${RAMDISK_DIR} ]; then
# NagiosUserUID=`id -u ${NagiosUser}`
# NagiosGroupGID=`id -g ${NagiosGroup}`
# mount -t tmpfs -o uid=${NagiosUserUID},gid={$NagiosGroupGID},size=${RAMDISK_SIZE}m tmpfs ${RAMDISK_DIR}
# su ${NagiosUser} -c "mkdir -m 0755 ${RAMDISK_DIR}/checkresults"
# else
# echo "ERROR: Unable to create ramdisk directory (${RAMDISK_DIR})"
# exit 1
# fi
# fi
# fi
#fi
Attached is a copy just in case you want to drop it in and set permissions. Bounce the 'nagios.service' and 'ramdisk.service' and let us know how things look.
Perry
hbouma
Post by hbouma »
Our RHEL 7.9 server doesn't have a /etc/init.d/nagios file. We do have a /usr/lib/systemd/system/nagios.service file. However, the nagios.service file doesn't match the file you sent me.
[Unit]
Description=Nagios Core 4.4.6
Documentation=https://www.nagios.org/documentation
After=network.target local-fs.target mariadb.service
[Service]
Type=forking
ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
ExecStop=/bin/kill -s TERM ${MAINPID}
ExecStopPost=/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd
ExecReload=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
ExecReload=/bin/kill -s HUP ${MAINPID}
[Install]
WantedBy=multi-user.target
root [/etc/init.d]
$ ll
total 112K
drwxr-xr-x.  2 root root 4.0K Nov 16 07:56 .
drwxr-xr-x. 10 root root 4.0K Oct 13  2020 ..
-rwxr-xr-x   1 root root  16K Jun  1 12:34 Security Agent1
-rwxr-xr-x   1 root root 1.9K Nov  1 05:10 Security Agent 2
-rwxr-xr-x.  1 root root  22K Aug 21  2013 Security Agent 3
-rw-r--r--   1 root root  18K May 22  2020 functions
-rwxr-xr-x   1 root root 1.6K Feb 13  2021 ncpa_listener
-rwxr-xr-x   1 root root 1.5K Feb 13  2021 ncpa_passive
-rwxr-xr-x   1 root root 4.5K May 22  2020 netconsole
-rwxr-xr-x   1 root root 7.8K May 22  2020 network
-rwxr-xr-x   1 root root 2.1K Jan 20  2020 npcd
-rw-r--r--   1 root root 1.2K Jan 15  2021 README
-rwxrwxr-x.  1 root root 1.8K Nov  9  2011 rrdcached
-rw-rw-r--   1 root root 1.8K Nov  9  2011 rrdcached.1
lrwxrwxrwx.  1 root root   18 Mar 23  2017 Security Agent 4
pbroste
Post by pbroste »
Hello @hbouma
Let's get an updated System Profile on this one.
To send us your system profile.
  • Login to the Nagios XI GUI using a web browser.
  • Click the "Admin" > "System Profile" Menu
  • Click the "Download Profile" button
  • Save the profile.zip file and send via Private Message
Perry
It looks like there is a typo in the /usr/lib/systemd/system/ramdisk.service file. It is missing a space in the paths when it creates the folders.
Edit the /usr/lib/systemd/system/ramdisk.service file and make sure the ExecStartPre has a space between the /var/nagiosramdisk/spool/checkresults and the /var/nagiosramdisk/spool/xidpe when it creates the folders.
It should look like this.
ExecStartPre=/usr/bin/mkdir -p -m 775 /var/nagiosramdisk/tmp/var/nagiosramdisk/spool /var/nagiosramdisk/spool/checkresults /var/nagiosramdisk/spool/xidpe /var/nagiosramdisk/spool/perfdata
Save the file and run the following to reload and restart the ramdisk service.
systemctl daemon-reload
Then see if the /var/nagiosramdisk/spool/xidpe and the /var/nagiosramdisk/spool/checkresults folders are created and that the files are processed.
Thank you.
hbouma
Post by hbouma »
Fixing the ramdisk.service seems to have fixed the ramdisk filling up and appears to be processing properly. The performance graphs are also now showing up after I fixed the corrupt rrd files as listed at https://support.nagios.com/forum/viewto ... 20#p338587
Profile coming via PM.
pbroste
Post by pbroste »
Hello @hbourma
Thanks for sending over the System Profile, we took a look through it and we are not seeing any issues that are sticking out.
Please let us know how things are looking and let us know where we need to direct our attention.
Perry
hbouma
Post by hbouma »
Everything seems to be working normally now. Go ahead and close this post.
